New and in trouble - JeepForum.com
 6Likes
  • 4 Post By 99sajeep
  • 1 Post By JeepN_A_CJ7
  • 1 Post By underscore
post #1 of 7 Old 08-23-2019, 04:22 PM Thread Starter
westondave
2006 WK
New and in trouble
Hi, I'm a novice as far as Jeeps go and not much better with engines although not scared of using a spanner or 2. Just bought a 2006 CRD 3.0. It was running fine as far as the engine goes then my son in law rings to say he just filled up and its started running rough. When I got chance to look it was billowing white smoke and cab also smelled, rev counter showed slightly rough idle (it was steady previously) so I lifted the hood to see if anything jumped out at me.Yep it did the engine looked like it was going to jump out. Am I right in thinking it's probably the head and most likely gonna cost way too much to repair?
Any suggestions good or bad will be appreciated.
westondave is offline
post #2 of 7 Old 08-23-2019, 04:41 PM
99sajeep
99sajeep's Avatar
2005 WK
Not to sound mean, but did you verify with your SIL that he filled it up with diesel? Hopefully, he didn't put gasoline in it...
'05 WK 4x4 Ltd 5.7L (mine) 200k+ club
'01 WJ 4x4 Laredo 4.7L (daughter)
99sajeep is offline
post #3 of 7 Old 08-23-2019, 05:23 PM
JeepN_A_CJ7
JeepN_A_CJ7's Avatar
1980 CJ7
Definitely what @99sajeep said, sounds like he might of filled up with unleaded......
wildbill23c likes this.
Always Jeepin!
*2007 WK QDII HEMI
*1980 CJ7 4.2L w/FAST FI
Silver WK Club
JeepN_A_CJ7 is offline
post #4 of 7 Old 08-23-2019, 10:43 PM
underscore
2007 WK
As the others said, verify what fuel was put in it. If it was gas you can try to clean it out but if things were damaged it might be beyond reasonable repair.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #5 of 7 Old 08-24-2019, 03:35 AM Thread Starter
westondave
2006 WK
Thanks for your replies, that thought has been going through my head too.
post #6 of 7 Old 08-24-2019, 04:21 PM Thread Starter
westondave
2006 WK
just a note my SIL says he filled with diesel so until I can get a mobile mechanic out I'm baffled.
post #7 of 7 Old 08-26-2019, 12:09 PM
Jambalam
Jambalam's Avatar
2007 WK
Possibly just a bad batch of fuel? Water in fuel sensor? Fuel filter? have you checked these?
Any DTC codes?
Because it went from tip-top to crappy after a fill up, I would start there (with the fill up). It sucks when coincidental timing sends you down the wrong path but I try to think of cause and affect in this situation.
2007 Grand Cherokee Limited CRD.
2006 Grand Cherokee Larado 3.7 V6.
Denver,CO
Jambalam is offline
