New to me 2005 Jeep WK 3.7l oil light - JeepForum.com
 2Likes
  • 2 Post By kdpearson03
post #1 of 2 Old 02-21-2020, 08:26 PM Thread Starter
kdpearson03
2003 WJ
Hi All,
I have a new to me WK had an oil light periodically come on. Found the sending unit was leaking and causing the light to flicker at low idle so I replaced it. Low speed flicker is fixed!
Now the every first time I start it the oil idiot light comes on solid however if I shut the engine off and start it right back up again the light stays out. This was happening periodically before I replaced the sending unit but now it does it every time I "first" start it.
I searched here but only found references to the light coming on intermittently due to faulty sending unit.
Any thoughts?
2004, 2003 WJ Special Edition
2004,2003, 2000 Jeep WJ Laredo
1996 Jeep XJ Forest Service Green
kdpearson03 is offline
post #2 of 2 Old 02-22-2020, 07:21 PM Thread Starter
kdpearson03
2003 WJ
Hi all,
It appears I fixed the problem. I pulled the new sending unit and reinstalled. Before I put the connector back on I cleaned it out really good with contact cleaner. Now it acts as it should. Apparently oil in the connector caused enough resistance to get a "trip the light" signal to the PCM.
Ken
schobbs and thearborbarber like this.
