Need Wiring Diagram - JeepForum.com
post #1 of 8 Old 01-05-2018, 01:04 AM Thread Starter
Samuel2001
2006 WK
Need Wiring Diagram
Good evening fellow Grand Cherokee enthusiasts.
I'm hoping someone here can give me a hand with my issue. I have replaced the engine on my '06 3.7L G.C. a couple of weekends ago and seem to have inadvertently pinched a wire or something similar. I was driving home from work this evening when the engine just died all of a sudden, I tried cranking to start but got nothing. All of the lights in the instrument cluster seem to be lit, but I don't get a crank at all. I plugged in my scanner and it is not comunicating with the PCM, it just keeps telling me "No Communication".
So I went under the hood and opened up the fuse box and found a 20A fuse to the PCM to be burnt out. I had a spare fuse that I could swap and did so. As soon as I tried to install it it immediately burnt out. So, now I have to track down a short and am wondering if anyone has access to a wiring diagram of the engine to PCM wiring harness diagram.
In advance, I'd like to thank everyone for their help.
Samuel2001 is offline
post #2 of 8 Old 01-05-2018, 02:35 AM
ma3x
2007 WK
Hello Samuel,
I attach you a link to the wiring.
I hope it will help you.
https://www.dropbox.com/s/01dh929gnj...%20WK.pdf?dl=0
In a gentle way, you can shake the world.
ma3x is offline
post #3 of 8 Old 01-05-2018, 06:21 AM Thread Starter
Samuel2001
2006 WK
Ma3x, thanks for the wiring diagrams you shared with me!
I really appreciate it, you're a life saver for sure!
post #4 of 8 Old 01-05-2018, 02:51 PM
Commander2007AB
2007 XK Commander
Need Wiring Diagram
Originally Posted by ma3x View Post
Hello Samuel,
Ma3x, maybe you have also the XK/XH wirings? Or know where to find? Especially looking for the 3.0 CRD engines wiring.
Commander2007AB is offline
post #5 of 8 Old 01-05-2018, 04:26 PM
kryton
Send me your email address via message & I will get the whole lot to you inc diesel
kryton is offline
post #6 of 8 Old 01-05-2018, 04:28 PM
Commander2007AB
2007 XK Commander
You have it.
post #7 of 8 Old 01-05-2018, 04:40 PM
kryton
Ah sorry just realised you said commander. The wiring should be the same though as platform & engines are identical. Just sent anyway but will see if mate has one specific for yours when I see him on Monday
kryton is offline
post #8 of 8 Old 01-05-2018, 04:59 PM
Commander2007AB
2007 XK Commander
Donít worry. I know, most of the electrical parts are the same. There are different just some engine controllers and I guess the rear a/c.
computer , pcm , wiring diagram
