Mysterious wet floor board (passenger side) - JeepForum.com
 1Likes
post #1 of 18 Old 10-19-2021, 04:44 PM Thread Starter
Hey12
Now I know this has been discussed previously but I hadn't found a discussion similar to what I have been going through. I have an 08 Jeep Commander 3.7 liter. The floorboard on the passenger side has been getting very wet but I can't seem to locate the source. The vehicle does not have a sunroof. It does not have any leaks through the windshield nor passenger door seal. I pulled the carpet back so I could let it dry and while so, ran the jeep through a car wash twice, but nothing. The ac has been running constantly and there are no drips whatsoever. It's not until I pulled the carpet back down after testing to find out it was moist again. One thing I noticed is when the carpet is pulled back, the metal floor board feels hot. I'm not sure what is going on. Maybe some of you can chime in and let me know what you may think. Thank you in advance
Hey12 is offline
post #2 of 18 Old 10-19-2021, 04:59 PM
Lockman75
Junior Member
Lockman75's Avatar
1975 CJ5
Your Heater core is leaking.
I was Schooled as a Mechanic 45 years ago. Then I became a Locksmith....... Who Knew ???
Lockman75 is offline
post #3 of 18 Old 10-19-2021, 06:21 PM
Planetcat
2010 WK
I second the heater core, but usually you can smell anti-freeze inside the jeep.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #4 of 18 Old 10-20-2021, 10:32 AM
Lockman75
Junior Member
Lockman75's Avatar
1975 CJ5
Perhaps he’s lost his sense of smell recently?? Just Say’n
post #5 of 18 Old 10-20-2021, 10:56 AM
Dadio73
your drain tube is blocked. look online and you should find a cure. in the summer when air is on it creates a lot of water from the warm, moist air going over the cold tubes and it has to go somewhere. something got in there and blocked it up. take some air and blow through the tube and that may fix it.
Greg
Dadio73 is offline
post #6 of 18 Old 10-21-2021, 01:52 PM Thread Starter
Hey12
If this was so, wouldn't I be able to see the actual leak happening?
Hey12 is offline
post #7 of 18 Old 10-21-2021, 01:53 PM Thread Starter
Hey12
Perhaps hes lost his sense of smell recently?? Just Sayn
This wouldn't be the case being that I just pooped 30 minutes ago and I can assure you, the ability to smell isn't lost.
Hey12 is offline
post #8 of 18 Old 10-21-2021, 01:55 PM Thread Starter
Hey12
There is no antifreeze smell inside nor sights of dripping anywhere. The carpet is still pulled back and I ran the ac for the last hour as I ran my errands. Condensate is leaking normally onto the cat where I hear hissing.
Hey12 is offline
post #9 of 18 Old 10-21-2021, 01:56 PM Thread Starter
Hey12
Greg
Where exactly is the tube from underneath? Any pictures of it being that I was never able to locate that tube.
Hey12 is offline
post #10 of 18 Old 10-21-2021, 03:45 PM
Vertisce21
Pretty sure the "drain tube" he is referring to would be the train tubes from your non-existent moon roof. My guess is they didn't read your whole post. But...I could be wrong.
Vertisce21 is offline
post #11 of 18 Old 10-21-2021, 10:37 PM
nvrdone1
2007 WK
the a/c drain tube on my 07 is right above the second cat. really hard to find. I had to start the car, turn on the a/c and look for drips under the car. be careful not to burn your hands. If there is nothing there check you tube. I remember a vid about cutting into the sound deadener under the right side of the dash to locate the drain tube and un plugging it. good luck.
nvrdone1 is offline
post #12 of 18 Old 10-22-2021, 02:03 PM
AdamEMT
AdamEMT's Avatar
Im having the same issue on my 06 4.7 with no sunroof. Its not antifreeze, definitely water.
AdamEMT is offline
post #13 of 18 Old 10-23-2021, 03:02 PM
nvrdone1
2007 WK
ok, here's the link i mentioned earlier. It worked on my 07 overland. hope it helps some one else. wasnt too hard. good luck.
tom_number1 likes this.
nvrdone1 is offline
post #14 of 18 Old 10-25-2021, 03:42 PM Thread Starter
Hey12
https://www.youtube.com/watch?v=DTi1-i4GRqY
Ill try this out but remember I am not seeing any actual dripping onto the floor.
Hey12 is offline
post #15 of 18 Old 10-26-2021, 06:09 PM
leadsled jeep
leadsled jeep's Avatar
Possible clogged sunroof drain lines?
For a WEAK and IGNORANT sheople, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
