My Jeep will only work in 4wd low - JeepForum.com
 4Likes
  • 2 Post By yzjwk
  • 2 Post By 2005JGC
post #1 of 6 Old 05-04-2021, 03:22 PM Thread Starter
Jradway719
Hello everyone, I’m in a unique scenario here. I recently just changed my drivers side CV axle in my 2006 Grand Cherokee Laredo with a Quadra drive 2 4wd system. After replacing the axle, it drove great for a few miles. As I got on one of the busier roads, I noticed an odd noise almost like he plastic in my fender well was catching. I hopped out and i didn’t see anything caught on the wheel. I hopped back in and tried to put it in drive and all my car did was rev up, acting like it was shifted into neutral. I couldn’t leave it on the side of the road, so I got the idea to switch it into 4wd low. Surely enough it worked until I received a “service 4wd” message on m dash. After it popped up, even in 4 low, it acted like it was in neutral. Any ideas? Is there a chance I installed the front axle wrong? Or could it be something far more expensive? Any advice or tips are much appreciated!
Thanks
J
Jradway719 is offline
post #2 of 6 Old 05-04-2021, 04:21 PM
yzjwk
yzjwk's Avatar
2005 WK
Thanks
J
I would guess You probably didnt seat the axle properly. If you break an axle, differential or driveshaft, you have no drive with this 4x4 system except for 4low which locks the transfer case.
underscore and 2005JGC like this.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #3 of 6 Old 05-04-2021, 11:10 PM
2005JGC
2005JGC's Avatar
2005 WK
Are you sure you have the correct axle?
IIRC, the non ELSD has a longer stub shaft on the drivers side than the elsd axle. This would do a couple things, it wouldn't seal (so you will have fluid leaking) and it wouldn't seat and hold itself where it belongs. Verify the part number you have. Even asking for the correct axle in my neck of the woods in no guarantee that the parts guy sold the right axle.
Otherwise, 100% what yzjwk said, the circlip on the end of the axle didn't get in as far as it needed to and the axle is pulling out of the differential.
yzjwk and underscore like this.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #4 of 6 Old 05-06-2021, 05:33 PM Thread Starter
Jradway719
Update: I pulled the axle again today to check and compared it to the old stub. Turns out that I had the wrong axle, The stub in the one I had just replaced was too short, ended up going to a different parts store and got the correct one and swapped it. I originally decided to swap it after I heard an odd grinding/clunking noise and noticed that my boot was torn on my old one. Well now that I’ve replaced it, the sound still hasn’t gone away when I drive, leaving me to wonder if it’s coming from my front diff, front drive shaft, or my T-case. I’m gonna throw it on jackstands tomorrow and see if I can pinpoint the noise. Does anyone else have experience with this odd grinding/clunking?
post #5 of 6 Old 05-06-2021, 07:52 PM
Geoskier9
Geoskier9's Avatar
Drain your fluids and see how they look, metal shavings is an obvious sign that something isn’t right. When I had my 2007 it also blew out the boot on the front drive shaft like others mentioned. Worth checking.
Last edited by Geoskier9; 05-06-2021 at 08:27 PM. Reason: Added driveshaft boot info
Geoskier9 is offline
post #6 of 6 Old 05-06-2021, 08:05 PM
yzjwk
yzjwk's Avatar
2005 WK
Update: I pulled the axle again today to check and compared it to the old stub. Turns out that I had the wrong axle, The stub in the one I had just replaced was too short, ended up going to a different parts store and got the correct one and swapped it. I originally decided to swap it after I heard an odd grinding/clunking noise and noticed that my boot was torn on my old one. Well now that Ive replaced it, the sound still hasnt gone away when I drive, leaving me to wonder if its coming from my front diff, front drive shaft, or my T-case. Im gonna throw it on jackstands tomorrow and see if I can pinpoint the noise. Does anyone else have experience with this odd grinding/clunking?
Check the front propshaft cv for tears and/or movement. Also check the diff level because like 2005jgc said, you could have lost a bunch.
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
