My JEEP's 65th anniversary - JeepForum.com
 1Likes
  • 1 Post By bumzo1
post #1 of 6 Old 07-13-2020, 07:25 PM Thread Starter
b18roman
I'm a newbie in the forum but not of owning Jeeps. This is however my first Grand Cherokee and it happens to be a 65th anniversary edition (2006). I'm having issues with the a/c only blowing cold air on the driver side and hot air on the passenger side. Also, last week it was blowing white smoke. The jeep did not give indication of any problems, no lights, and it was not overheated. My mechanic said it was the blend doors but what about the white smoke? He couldn't say.
Now, it only smoked for a few minutes, I turned a/c off, turned it back on an hour or so later and it stopped smoking. It only happen once.
I like to fix it myself, if someone could send me links on how to take out the dash correctly, I would be most grateful.
Engine v6
automatic
4x4
no aftermarket installed
Bonnie
U.S. Navy Veteran.
b18roman is offline
post #2 of 6 Old 07-13-2020, 10:31 PM
bumzo1
bumzo1's Avatar
2005 WK
Does your Jeep have the dual zone automatic climate control? If it doesn't, cooling on the drivers side and hot on the passenger is an indication that you are low on refrigerant and most likely have a leak somewhere. I would recommend taking it to a shop and having them do a pressure/leak test. I had trouble with the schrader valves leaking on my 2005 but it could really be anywhere.
b18roman likes this.
'05 WK 3.7L QT1 OME MD lift
'09 WK 5.7L QDII Stock for Now
Khaki WK Club Member #1
bumzo1 is online now
post #3 of 6 Old 07-14-2020, 01:41 PM Thread Starter
b18roman
I took it to Firestone today, describe the symptoms. They are "confident" its not a leak otherwise I would get no cold air at all. I don't know how much I can trust them. And it's not a dual systems. The only videos and information I find is for WJ, prior 2005. The 2006 grand cherokee I do find is on the actuator replacement and no blend doors.
Your help is much appreciated.
Thank you.
b18roman is offline
post #4 of 6 Old 07-14-2020, 07:08 PM
bumzo1
bumzo1's Avatar
2005 WK
Did they actually hook it up to a set of gauges to check the pressures? How long has this behavior been going on for? Try turning the hot/cold knob and see if the temp changes. If it does I think the blend doors are working properly. Do the same for the other knob and see if it directs air to the appropriate vents. When the A/C went out on my '05 there was a temperature gradient between driver and passenger, and then a few days later it didn't cool at all. In my case it was a leaky schrader valve.
Looks like this other forum member is having the same issue https://www.jeepforum.com/forum/f67/...oblem-4400159/
post #5 of 6 Old 07-15-2020, 07:36 AM
nvrdone1
2007 WK
if you have a leak, generally its a small one and as the freon leaks out the cooling ability declines. Id run fast away from that Firestone shop and find one that does a/c work.
nvrdone1 is offline
post #6 of 6 Old 07-15-2020, 09:29 AM
Grinmaul
2008 WK
Thank you.
They my be confident, but they are probably still wrong. just went through this myself. turns out it was a leak.
take it somewhere else.
2 2008.5 WK CRD's, 2005 WK Limited 5.7
Grinmaul is offline
