Movable license plate - JeepForum.com
 1Likes
  • 1 Post By 3Recon
post #1 of 12 Old 10-22-2021, 03:11 PM Thread Starter
3Recon
3Recon's Avatar
2009 WK
Hi all, hey have a WK hidden winch nearing completion end ! but anyway I've viewed a lot/ a few of swing down license plate hangers and then I filter through the reviews which just muddies the waters for something so simple. and I'm on the fence whether to make (leaning on the side make my own) or buy one other WKers have tried and experienced. What's your take. under 25 dollars
3Recon is offline
post #2 of 12 Old 10-22-2021, 05:24 PM
ravenworks
ravenworks's Avatar
If the fairlead rollers are not hidden you can use 3/4" conduict hanger/clamps to clip onto .
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 12 Old 10-23-2021, 12:42 PM Thread Starter
3Recon
3Recon's Avatar
2009 WK
Thanks for replying ravenworks but using S. rope with a Hawse fairlead which protrudes just under an inch.
3Recon is offline
post #4 of 12 Old 10-23-2021, 01:07 PM
tom_number1
2007 WK
Would you mind sharing which components you ended up using for your hidden winch? In particular, which mounting system? Thanks in advance!
Tom
tom_number1 is offline
post #5 of 12 Old 10-25-2021, 04:28 PM Thread Starter
3Recon
3Recon's Avatar
2009 WK
First of all Tom welcome to the forum /WK in response to your question about the Winch plate I'm working with. It's a HK Off road winch plate as a starting point. I went with this one because they had a short lead time (had) and worked with me on a couple changes. I was able to suggest in their design and they were happy to delete some of the gusting that runs along their attachment points inline with vehicle. and after mounting have a few more for the 2009 (can only speak of my year) I needed to be able to attach my Roadmaster system for flat towing.
3Recon is offline
post #6 of 12 Old 10-26-2021, 11:16 AM
tom_number1
2007 WK
Thanks very much for both the welcome and the info! I do appreciate it.
Tom
post #7 of 12 Old 10-30-2021, 03:20 AM Thread Starter
3Recon
3Recon's Avatar
2009 WK
Tom_number1 here is the modified HK offroad winch plate on a 2009 Grand which is set up for flat tow with a RoadMaster system. putting line on tomorrow.
19GCTrailhawk likes this.
3Recon is offline
post #8 of 12 Old 10-31-2021, 09:36 PM
tom_number1
2007 WK
Thanks very much 3Recon! That looks very sharp.
post #9 of 12 Old 11-05-2021, 07:47 PM Thread Starter
3Recon
3Recon's Avatar
2009 WK
Well here it is, an idea I was tinkering with and it seem to work
3Recon is offline
post #10 of 12 Old 11-06-2021, 01:07 PM
tom_number1
2007 WK
Still looking really sharp 3Recon, well done! Did you end up making your own license plate hanger or buy a manufactured one?
Edit: I see from the other thread that you made your own. Looks good!
Tom
post #11 of 12 Old 11-06-2021, 02:01 PM Thread Starter
3Recon
3Recon's Avatar
2009 WK
I ended up doing the mod. on my original license plate holder. Just have to remove two lag screws for license plate along with spacer and ready for winch recovery. I have plastic mushroom like fastener on top edge of spacer between license frame that's attached to bumper. This was just a quickly (R&D) to get vehicle back into my driving rotation. spacer is coated with water proof Varathane plastic coat.
3Recon is offline
post #12 of 12 Old 11-07-2021, 02:51 PM
tom_number1
2007 WK
I really like that look! I'd like to do somewhat the same but I also have to deal with the complications of having a CRD. Thanks again!
Tom
