Moog Strut Mount - Bearing Not Included? - JeepForum.com
 5Likes
  • 1 Post By Rtbrjason
  • 2 Post By Grinmaul
  • 2 Post By 2005JGC
post #1 of 7 Old 07-22-2019, 03:30 PM Thread Starter
bener_m
Hi everyone, I'm just a bit confused, I'm wanting some Moog strut mounts for when I fit my Dobison's lift, but the Rock Auto listing says 'bearing not included'
I can't find this mentioned anywhere else, and Moog has not returned my email - does anyone know if this is really the case?
Do people who buy this kit just re-use the OEM bearing? I couldn't find a listing for the bearing on its own.
Part number is: MOOG K160050
bener_m is offline
post #2 of 7 Old 07-22-2019, 03:36 PM
Rtbrjason
Rtbrjason's Avatar
2008 WK
I just replaced every bit of suspension on mine. Used the moog mounts as well. Pretty sure there is no bearing involved.
bener_m likes this.
Rtbrjason is online now
post #3 of 7 Old 07-22-2019, 03:50 PM
Grinmaul
2008 WK
The strut does not turn so there is no bearing, what you got is all you need.
underscore and bener_m like this.
2008.5 WK CRD, 2005 WK Limited 5.7
Grinmaul is offline
post #4 of 7 Old 07-22-2019, 04:06 PM Thread Starter
bener_m
Thanks, that's interesting as the other brands all say bearing included!
bener_m is offline
post #5 of 7 Old 07-22-2019, 04:54 PM
2005JGC
2005JGC's Avatar
2005 WK
As stated, there is no bearing. On a mcPherson strut assembly, there is a lower control arm, knuckle and the strut that bolts to the knuckle and up to the strut tower. The whole strut turns as the wheel turns on this type of setup and will have a bearing or thrust washer up on top. On the WK it is a coil over with the strut mounted more or less solidly (via bushings/mounts) it does not rotate with the steering so there is no bearing mounted on top.
That is interesting that some manufacturers are calling for a bearing.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #6 of 7 Old 07-22-2019, 05:29 PM
jeeptorino68
1992 XJ Cherokee
Is this what the washer spacer thing is that comes with the bilstein 5100 front shocks??
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #7 of 7 Old 07-22-2019, 08:20 PM Thread Starter
bener_m
Thanks, I'll go with the Moog ones then! That does make sense, I was just really confused that they say there is a bearing included.
bener_m is offline
