Lowering the profile of my roof rack - JeepForum.com
 1Likes
post #1 of 21 Old 11-23-2015, 01:42 PM Thread Starter
Nick_Will
2006 WK
Hey guys, I've been looking for some ways to lower the profile of my roof rack. I know I have seen some threads somewhere with some options, but I'm a part of so many forums that I can't find what I am looking for! If my memory serves correctly, one of the ways to lower the profile was by flipping the cross bars upside down or something. The image is what I am dealing with.
Anyone have any leads to send me in the right direction? Thanks!
Nick Williams
Nick_Will is offline
post #2 of 21 Old 11-23-2015, 03:31 PM
youngPreacher
2006 XK Commander
I used uni strut, bolts washers and some composite shims to put mine as close as possible
~XKs LEAD THE WAY.~ '06 XK.Hemi.SCT 3872.Modified Rusty's lift
youngPreacher is offline
post #3 of 21 Old 11-24-2015, 09:38 AM Thread Starter
Nick_Will
2006 WK
You mounted the cross bars directly onto to the rails in the roof?
Nick Williams
post #4 of 21 Old 11-24-2015, 09:43 AM
youngPreacher
2006 XK Commander
I replaced the oem cross bars with Unistrut , and yeah directly to rails. Big washer slid into the rails. I have more pics, I'll have to find them
post #5 of 21 Old 11-25-2015, 11:13 AM
Xride
Is there room under the strut for you to lint the basket on the bottom of the strut?
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #6 of 21 Old 11-25-2015, 12:23 PM
youngPreacher
2006 XK Commander
Yes because the commander's roof is higher in the middle than the sides, and mine are actually touching the middle just a bit. They are as low as they can be. I probably should add another spacer to get it off the roof tho. But it has space underneath on the sides for basket mounts. I'll try to post some pics later
Another thing to note which is weird is that the roof rails are wider by 2"(approx) at the front than at the back, and the roof slants to the back. You can't really tell any of that until you're up there measuring it.
post #7 of 21 Old 11-25-2015, 01:16 PM
youngPreacher
2006 XK Commander
Pretty low
post #8 of 21 Old 11-25-2015, 01:18 PM
youngPreacher
2006 XK Commander
Top
post #9 of 21 Old 11-27-2015, 07:14 PM Thread Starter
Nick_Will
2006 WK
I've never heard of Unistrut bars before. Is that a brand or something?
post #10 of 21 Old 11-27-2015, 07:40 PM
ruggedscotsman
2007 WK
It's a construction material used for structural mounts, shelving, seismic bracing etc. C- chanel galvanised steel with slot holes on one side, and rolled edges on the open side.
ruggedscotsman is offline
post #11 of 21 Old 11-27-2015, 08:26 PM
youngPreacher
2006 XK Commander
you can buy it at Home Depot or Lowes in the electrical section
post #12 of 21 Old 11-27-2015, 08:27 PM
youngPreacher
2006 XK Commander
Looks like this
post #13 of 21 Old 11-27-2015, 09:28 PM
Xride
The best part about strut is all the brackets and stuff that bolt into it with spring nuts or clip into the rolled edges. Can build shelving from it that will hold a car for half the price of pre built shelving.
Xride is offline
post #14 of 21 Old 12-26-2016, 12:20 PM
commanding2016
Nice, thanks for posting this. I was about to drop $100+ on some rails to use for my rack. Factory XK rails are HUGE! This is a much better look / option and will save me enough coin to pay for a couple of my LED's. Thank you
commanding2016 is offline
post #15 of 21 Old 12-26-2016, 05:55 PM
Budasac
Budasac's Avatar
2005 WK
I did a write up about it a few years ago. There is info in my build thread in post #279.
Basically you remove the four hand tighteners on the bars and replace with bolts and washers. Then you flip the Rola hardware upside down. You can get the rack to sit just on top of your roof rails.
Budasac is offline
