Loud Clunk/Banging Sound - JeepForum.com
post #1 of 16 Old 10-07-2019, 12:26 PM Thread Starter
JustChillin
When slowing down I'm experiencing a loud banging and clunking sound coming from the front end. I have a mechanic friend looking at it and he can't recreate the issue when its up in the air, only when driving. he did notice a blown front axle diff bushing blown out. Anyone know what this could be? i was thinking it was driveshaft related, but he didn't think it was.
2009 WK 3.7 4x4
quad I
144k miles
JustChillin is offline
post #2 of 16 Old 10-07-2019, 05:11 PM
YouStupidBunny
YouStupidBunny's Avatar
2007 XK Commander
Please, provide the conditions when you hear the noise. Coming to or from a stop? Do you notice it when you hit a bump or just after? Any specific side?
YouStupidBunny is offline
post #3 of 16 Old 10-08-2019, 08:50 AM
Mainsail
2005 WK
If it's when you first let your foot off the gas pedal it may be the front axle bushings. If you have 144K and are still on the original set they can't be long for this world. I have an appointment on the 11th to have mine replaced (at 115K) for around $1K, ouch...
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #4 of 16 Old 10-08-2019, 09:26 AM
Raffish
2005 WK
Maybe try it yourself, not too hard and lot's of writeups around.
Or road trip to Calgay and I'll do it for ya..
I have my second set in the garage waiting to go on..
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, MBRP SS, 250xxxkms
Raffish is offline
post #5 of 16 Old 10-08-2019, 12:21 PM Thread Starter
JustChillin
maybe the past year i noticed a slight surge when i let off the accelerator. didn't happen all the time,but if i needed some speed and let off quickly i would feel the jeep surge a bit. now, it doesn't even seem drive-able. it accelerates fine. once you left of the gas it surges and clunks around. sounds and feels like something is being hit with a 3lb hammer.
post #6 of 16 Old 10-08-2019, 12:30 PM Thread Starter
JustChillin
are you getting loud noises? what signs did you have?
post #7 of 16 Old 10-08-2019, 12:45 PM
Mainsail
2005 WK
I don't have the room or the proper tools to do it right. I do almost all my own work, but sometimes it needs to be farmed out.
Mainsail is offline
post #8 of 16 Old 10-08-2019, 07:14 PM
nvrdone1
2007 WK
mainsail: who wants to rip you off for a grand? I had mine done 3 months ago for $250.00 + parts.
nvrdone1 is offline
post #9 of 16 Old 10-08-2019, 07:19 PM
JustCallLance
2006 WK
IT might sound stupid, but when was the last time you had the front brakes done? if it was recent, did you double check the install? Could be a missing bolt, missing clip, something simple but easy to over look.
If it wasn't recent, are they (over)due?
Again, I know it sounds stupid, but sometimes its the easiest things that get overlooked.
JustCallLance is offline
post #10 of 16 Old 10-08-2019, 07:44 PM
Mainsail
2005 WK
Northridge4X4 here locally. I found their quotes matched everyone else's (that is reputable) around town. Who did yours?
Mainsail is offline
post #11 of 16 Old 10-08-2019, 09:36 PM
YouStupidBunny
2007 XK Commander
I would first look at the front axle bushings. Do you notice it when shifting from park to reverse or drive? If that's your problem, how big it is depends on your tool box, skill, and patience level. Here are a couple videos (part 1 and 2) to watch and see if it's something you want to try.
post #12 of 16 Old 10-09-2019, 12:49 AM
Chirpz
Chirpz's Avatar
2007 WK
I have a writeup on this procedure here:
https://www.jeepforum.com/forum/f67/.../#post40730243
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #13 of 16 Old 10-09-2019, 08:25 AM
nvrdone1
2007 WK
mainsail: Olympic 4x4 in Snohomish. they didn't remove the diff - just dropped it down & rotated it.
nvrdone1 is offline
post #14 of 16 Old 10-09-2019, 09:25 PM
Chirpz
Chirpz's Avatar
2007 WK
That MIGHT be possible if you have the right equipment. Not so easy if you are laying on your back in your driveway.
Chirpz
Chirpz is offline
post #15 of 16 Old 10-11-2019, 10:56 PM
Mainsail
2005 WK
When I dropped it off I asked if they had gotten the diff fluid and the friction modifier and he looked a little confused, then the light came on.
I told them about the rotating vs dropping the whole diff and that's what they did.
It took them 4 hours vs the six they quoted me. All the bushings were bad, this one was the worse and the front one (the easy one) looked the best. The clunking is gone.
Mainsail is offline
