looking to go higher... - JeepForum.com
post #1 of 3 Old 10-27-2021, 08:56 PM Thread Starter
madmader
Question. has anyone tried running the OME 2" kit in conjunction with the Ruff Country spacer kit? I just have JBA's upper control arms, I just have not yet installed them... I currently have the RF spacer kit installed with 31" tires. I would like to get up to 33"....
madmader is offline
post #2 of 3 Old 10-27-2021, 10:33 PM
Vertisce21
Yep...people do that all the time. It's a "Frankenlift" as you are mixing parts from OME and whatever budget lift to make a taller lift. Keep in mind that this puts a lot of stress on your CV joints and you will likely either have to replace them often or spend a LOT of money on a set that can handle the angle. That or lower your front diff which kind of makes lifting that high pointless if you ask me. You will also likely have to get a new front drive shaft among a few other minor upgrades. You already have the UCA's so...there's that. Me too. Mine just came in and now I have to install them.
If you are going to go that tall of a lift, I recommend you look at getting the Bilstein 5100 struts and shocks. The forward struts give you a variable lift that you can adjust, you get a better overall ride and only need the 2" spacers for the rear.
Good luck!
Vertisce21 is offline
post #3 of 3 Old 11-03-2021, 08:15 PM Thread Starter
madmader
Thank you sir! Much appreciated!
madmader is offline
