Looking for Bolt Size (Part #6101838) Rear Bump Stop Bolt - JeepForum.com
post #1 of 2 Old 06-14-2021, 01:13 PM Thread Starter
nwoods
2006 WK
I need to order longer length bump stop bolts, and I am not sure the size of the existing bolt I need to replace. Yes, I could go rent a spring compressor and disassemble the rear end and pull the bolt out, again, but I am hoping there is a way to figure out this bolt size online.
Its part #7 in the rear suspension diagrams. It holds Part #6 (the bump stop receiver cup) to the frame). It's MOPAR Part # 6101838
It has a 10.9 stamped on it. I can't remember for sure, but I think its 15mm hex head, and its maybe 1.5" long, possibly shorter.
Does anyone have a clue what size bolt this is?
2006 Jeep WK on 33ís
HAM: KI6FPO
Offroad Photography:
nwoods is offline
post #2 of 2 Old 06-19-2021, 11:24 PM Thread Starter
nwoods
2006 WK
Answer: M10x1.5 Course Thread, Material code 10.9
Tip, if you are looking to replace with with longer bolts, to insert a spacer above the receiver cup, Try using an M10x70 Course, full length thread
HAM: KI6FPO
nwoods is offline
