leaking diesel fuel injector - Page 3 - JeepForum.com
post #31 of 43 Old 12-09-2014, 07:56 PM
10Xk
2014 WK
Originally Posted by TangoTango
put the fabricated pins in the injector cylinder to plug the hole..then soaked the injector cylinder overnight with injector cleaner ... then next day shop vac and air spray it out (shield spray with rag so it doesn't go all over) then remove the pins and wipe clean. that way cylinder comes out like new.
Shop vac injector cleaner, isn't it flammable?
10Xk is offline
post #32 of 43 Old 12-09-2014, 08:09 PM
Tango.
Originally Posted by denniscdunbar View Post
Does this look like the same issue you had?
https://www.youtube.com/watch?v=KS4TuYDjurc
Dennis
yes that is the same problem.
basically the copper o-ring at the bottom of the injector has gone out.
Life is hard-John Wayne
Tango. is offline
post #33 of 43 Old 12-09-2014, 08:11 PM
Tango.
yes, good point, probably best to stick with cleaning it out with the airgun.
Tango. is offline
post #34 of 43 Old 12-09-2014, 10:51 PM
denniscdunbar
2008 WK
Fuel return hose removal
Do I need to disconnect the return fuel hose before removing fuel line from common rail -> injector, electrical connector and bolt. If so, how is that done.
Dennis
denniscdunbar is offline
post #35 of 43 Old 04-02-2015, 12:16 PM
Craigyfm
2006 WK
I also need the know how, have you gotten the small black clip off the injector
Craigyfm is offline
post #36 of 43 Old 04-04-2015, 08:56 AM
denniscdunbar
2008 WK
You need to push down on the round ring to release the fitting. Be careful to not damage the o-ring. You can go to your local Jeep dealer to get the o-ring.
https://www.jeepforum.com/forum/f67/c...l#post27283722
post #37 of 43 Old 06-03-2016, 04:51 PM
Whitbread
2008 WK
I hate to call people out, but this is absolutely incorrect and just cost me a return harness. The locking ring needs to be lifted UP, not pushed down. Pushing down breaks the "feet" that latch onto the return nipple on the injector. Once the parts were removed, it was easy to see pushing the lock ring down was not correct. Too bad hindsight is 20/20.
Whitbread is offline
post #38 of 43 Old 06-13-2016, 12:50 AM
ggrassmid
2008 WK
Whitbread... have you done the injector copper ring replacement? I just heard/found one of mine is bad. Any help would be wonderful! Also, Gaylord, MI?
ggrassmid is offline
post #39 of 43 Old 06-13-2016, 12:41 PM
Whitbread
2008 WK
Yup, I did the driver side rear cylinder. Outside of breaking the return line clip due to either incorrect instructions all over the net or a change in the harness since mine is a very late 08, it was smooth sailing. I'm 20 mins east of Gaylord.
post #40 of 43 Old 06-15-2016, 04:45 PM
Tango.
there is this link and it has a couple others attached to it. like said above be careful with the clips on the return line.
https://www.jeepforum.com/forum/f67/c...69/index4.html
what side leaked? I may have an extra injector shield pad.. it's used but good condition. PM me if you needed with the side.
Tango. is offline
post #41 of 43 Old 06-15-2016, 06:25 PM
ggrassmid
2008 WK
Fortunately I have pulled the foam and plastic cover off the engine after I bought it. I wont be needing that.
My rear passenger side has started to leak. Im going to replace all of them.
post #42 of 43 Old 06-16-2016, 10:32 PM
jediknight
2008 WK
X2
I'm with you Whitbread
And what shocks me is when I post pictures with explanation and still there are people managing to advise in the wrong way ... they probably work for chrysler or something!!
Post 34 @
https://www.jeepforum.com/forum/f67/c...01/index3.html
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #43 of 43 Old 06-17-2016, 04:43 AM
ggrassmid
2008 WK
Thanks for the help. I will be doing my 6 tomorrow morning. I have less than 200 miles on the one bad one, so gunk build up should be pretty minimal. I bought two cans of Seafoam to soak the holes with and will probably soak the tips of the injectors in it as well to clean up some gunk on those. I didn't get any aluminum rods yet, but need to stop at the hardware store to pick some up. I have all the parts: hold down bolts, cooper washers, and new return line o-rings to all go on.
crd , diesel , fuel , injector , leak
