Largest Tires on 18" Wheels - JeepForum.com
post #1 of 8 Old 07-11-2019, 11:49 PM Thread Starter
babylondown
Hey guys. I have a 2010 North Edition and it comes stock with 18" wheels. I was wondering what the largest tire I can fit with and without mods?
I know someone who has a set of 265/65/18 KO2's and wanted to know if I can get them on before going to the mechanic. I have no problem doing the pinch weld mod and adding 1.5" spacers if need be. A modest lift would be coming eventually.
Thanks guys!
babylondown is offline
post #2 of 8 Old 07-14-2019, 01:07 PM Thread Starter
babylondown
Nobody?
post #3 of 8 Old 07-14-2019, 09:18 PM
caulk04
2008 WK
That tire is going to need a mild lift first. PW and a spacer as well. 1" spacer is plenty. More spacer = more PW rub.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 8 Old 07-17-2019, 10:43 AM Thread Starter
babylondown
Does anyone know the largest tire you can fit without a lift or spacer mod? If just adding spacers, what kind of extra clearance would I receive?
post #5 of 8 Old 07-17-2019, 01:21 PM
caulk04
2008 WK
You might be able to cram that size of a tire without lift if you go more tame on the tread design. The BFG AT's are a pretty meaty and square cornered tire that eats up room. I ran a 255/60-18 at stock height. It's not much bigger than stock, but I thought it looked good without being too 'stuffed'. Any larger than that and you need to address the upper ball joint stud by trimming or using spacers.
I run 265/65-18 now but have 2" or maybe a bit more lift. 1.25" spacers on my Jeep and I've massaged the PW some.
caulk04 is offline
post #6 of 8 Old 07-17-2019, 01:38 PM
underscore
2007 WK
Check the sticky, it lists the sizes that fit. Factor in any sag you have from old springs.
07 WK CRD//QDII//OME MD//OMG WTF BBQ [daily]
91 Celica GTFour RC [for sale]
underscore is offline
post #7 of 8 Old 07-18-2019, 08:56 PM Thread Starter
babylondown
You're going to think I'm crazy, but I cant seem to locate this stick you're referring to.
post #8 of 8 Old 07-19-2019, 10:52 AM
underscore
2007 WK
The first question of the FAQ: https://www.jeepforum.com/forum/f67/...-wk-xk-703598/
