Key Fob broken, anyway to use the cut key to start the jeep? - JeepForum.com
 3Likes
  • 2 Post By yzjwk
  • 1 Post By groverson
post #1 of 9 Old 05-22-2020, 06:57 PM Thread Starter
JeepCherokeeVal
I have a 2008 Grand Cherokee, and while replacing the fob battery a part of the circuitboard flew off. I do not have anything to solder it back on with. Is there any way to start the engine with just the cut key (valet key)? The jeeps battery may be dead as well. If the fob is broken and I have the Valet key inserted, can this still start the car?
JeepCherokeeVal is offline
post #2 of 9 Old 05-23-2020, 12:48 PM
Gray203m
2008 WK
Doubt it. The fob transmits a code to the ignition module to allow starting. You can try it, but I wouldn't bet on it
2008 WK CRD North
GDE Eco Tune, DPF Delete
2" RC lift, 265/65R18 Duratracs
Gray203m is offline
post #3 of 9 Old 05-23-2020, 01:26 PM
acabtp
2005 WK
no way to run it w/o the chip key. also if you have less than 2 working chip keys, there's no way to add a new one w/o a locksmith or the dealer programming it to the jeep.
'05 WK Limited 5.7 Hemi
acabtp is offline
post #4 of 9 Old 05-23-2020, 03:00 PM
brent_m
2007 WK
you might try and find someone good with electronic repair in your area. surface mount soldering isn't difficult, but it's more difficult than soldering leaded components.
do you have the component that popped off the board? and is it usable still?
2007 Jeep Grand Cherokee Overland
5.7 Hemi - Airaid CAI - Magnaflow
brent_m is offline
post #5 of 9 Old 05-23-2020, 06:48 PM
yzjwk
yzjwk's Avatar
2005 WK
The FOB transponder doesn’t require a battery to start the vehicle . Battery is only for the lock/unlock buttons.
azzkicker and underscore like this.
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #6 of 9 Old 05-23-2020, 06:51 PM
JeepRonibo
JeepRonibo's Avatar
2014 WK
This would be great news for the OP!
2014 Grand Cherokee Overland V6
2008 Dodge Durango Limited 5.7L
2002 Chrysler 300m Special 3.5L
JeepRonibo is offline
post #7 of 9 Old 05-23-2020, 09:53 PM
acabtp
2005 WK
OP didn't say what part flew off, hopefully part of the unlock circuitry and not the transponder then
acabtp is offline
post #8 of 9 Old 05-24-2020, 12:09 AM
underscore
2007 WK
There's two parts to the circuitry in the key and they work separately. Depending on what broke it might still work, you may as well give it a shot.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #9 of 9 Old 05-24-2020, 11:19 AM
groverson
groverson's Avatar
1936 CJ3A
I learned my lesson. Paid the dealer $250 for a second key.
As soon as I had two working keys I made a third myself. Ordered a blank on Amazon for $8 and programmed it with the two working keys. Did this to my wife’s Grand Caravan too....
Sent from my iPhone using Tapatalk Pro
JeepRonibo likes this.
groverson is offline
