It's about time for me to kick off my build thread! Will follow up with details and pictures for each modification.
Starting point:
Modifications:
How she looks today
Starting point:
- 2008 Grand Cherokee Laredo
- 4.7L V8
- QTII, 3.73 gears
- RFE545 transmission
- NV245 transfer case
- Tow package with hill control
Modifications:
- ABS honeycomb grille modification
- JBA upper control arms
- OME MD springs (front) MD springs (rear)
- Bilstien 5100 struts and shocks
- Rusty's adjustable trackbar
- Front pinch weld modification
- Gas tank skid modification
- Spidertrax 1.5" spacers
- Mopar Recon wheels 17x7.5, 5.5" BS
- Nitto Ridge Grapplers 285/70R17
- HK Offroad front shackle tabs
- Anzo black projector / halo headlights
- Jeeperf 5100 coilover conversion kit
- Brake motive drilled and slotted rotors
- Moog lower control arms
- Moog upper strut mounts
- Moog strut isolators
- Trim front bumper
- Jeeperf HD differential bushings
- Swap QTII front differential for QDII with eLSD
- Switch / Relay for QDII eLSD
- Eaton TrueTrac LSD for rear differential
- Motive 4.11 gears
- HK Offroad Kratos tire carrier
- Riddler Mfg rear differential cover
- Tom Woods front and rear double cardan drive shafts
- Asfir front, t-case, and transmission skid plates
- Bedliner side rail, rear step, grille
- Timkin hubs
- Mevotec TTX lower ball joints
- Replace interior lighting (Phillips LEDs)
- Jeeperf Superflex tie rods
- HK Offroad Krawler rock sliders
- Custom trunk plate for Milwaukee Packouts
- Metalcloak rear bumpstops (JK)
- JKS bumpstop spacers
- Core 4x4 Tier 4 rear control arms, with bent uppers for clearance
- RCV Performance ultimate IFS axles
- Addco rear sway bar
- JKS quicker disconnects (rear)
- Energy suspension poly rear sway mounts
- K&N intake
- SuperChips Flashpaq (91 performance tune)
- Custom heim steering
- HK Offroad Street Sweeper bumper
- Custom main tube for bumper
- Baja Designs SAE Fog lights
- 250-400 amp alternator from JS Alternators
- Comeup Seal Slim 9.5rs winch with synthetic line
- Factor 55 flatlink with rope guard
- PRP Comp Elite seats (driver and passenger)
- More front pinch weld trim and plate work
- Trim rear subframe for clearance
- Kilmat sound deadener
How she looks today
