Jeep wont shift out of low gear - JeepForum.com
post #1 of 5 Old 02-23-2020, 01:52 PM Thread Starter
steve12327
Hello
My 2007 Jeep Grande Cherokee, diesel wont shift out of low gear. Everything else works normally. It did this several times and I shut off the engine and restarted the Jeep , then it worked. I have google searched for days and cant find anyone who has had a similar problem.
I cleaned the ESM. I found a post where the ESM can get graphite in between the contacts but it didnt work.
Before it stopped shifting completely it would occasionally rev up but not really go anywhere, like the torque converter wasnt working properly. Again, shutting off and restarting fixed the problem.
If anyone has any ideas or where to look , please help.
Thank you
steve12327 is offline
post #2 of 5 Old 02-23-2020, 02:32 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Welcome to the forum. The very first thing you should do is hook up a quality diagnostic scanner (one that can read the tranmission) and see if there are any transmission related diagnostic trouble codes (DTC). Some low end scanners will give you a P0700 code which is basically telling you that there is a problem with the transmission. Next check the transmission fluid level using the instructions in the Factory Service Manual (FSM). You'll need a dipstick marked in 5 mm increments, a way to read the transmission fluid temperature, and the fluid/temperature level chart from the FSM. When is the last time the transmission was serviced? How many miles on the vehicle?
Once you've established the fluid level and service status is current and it still acts up, there are a few other things that can cause similar problems. Check for any ABS and/or ESP DTC's. Wheel speed sensor(s), and the conductor plate on the valve body can cause all kinds of strange issues.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, AFE Air Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS and HP tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads w/new valve seats, SRT Reps with 265/45&295/40X20's. Also 05 Hemi LX modded exactly like WK and Comp Cammed 06 300CSRT8.
90grandoneer is offline
post #3 of 5 Old 02-23-2020, 04:47 PM Thread Starter
steve12327
Thank you, that gives me quite a bit to start with. Jeep has about 160000 km. I have only had it for about 5000 km so I am not sure when the transmission was serviced last, possibly never.
post #4 of 5 Old 02-23-2020, 06:27 PM
90grandoneer
2006 WK
So, you're not even sure the fluid level is correct?? I think I'd start with a fluid/filter change......no flush. When doing this make sure you note if there is any debris in the pan or if it relatively clean.....just a thin film of gray/black powdery stuff.
post #5 of 5 Old 03-08-2020, 09:42 PM Thread Starter
steve12327
My stuff from Amazon finally arrived. I can check things now. Transmission level is fine and oil looks ok. I will change it when it melts down some. I have to do it in a snow and ice filled driveway and it was -28c this morning. My code reader says P0705 and P0730. No other codes. I have been researching a lot more since I got the codes. I am leaning towards conductor plate, TCM or ESM. I will keep you posted.
shift
