Jeep WK Exhaust Heat Shield - JeepForum.com
post #1 of 5 Old 12-17-2017, 04:52 PM Thread Starter
bucks09wk
2009 WK
Hi,
Wondering if anyone else has or had this problem.
My exhaust heat shield is loose and rattles crazy at idle. Around 500-600 RPM. Anything above that, it goes away.
What is the best solution to fix it?
bucks09wk is offline
post #2 of 5 Old 12-18-2017, 04:11 AM
caulk04
2008 WK
Which shield?
Unless you live in a seriously hot climate, rip it off. If you live in a real hot place, rip if off.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 5 Old 12-18-2017, 05:49 AM
mfelthousen
2015 WK
They usually rot at the fasteners, because of the dissimilar metals being in contact with each other. I used fender washers and new speed nuts / clips to replace the original fasteners. Sometimes the stud itself rusts off, in which case that will have to be replaced first (haven't had to do that yet.
The pics below show the before / during / after of a recent repair. The black spray was undercoating, but I'd recommend using high temp paint instead.
Mat
mfelthousen is offline
post #4 of 5 Old 12-18-2017, 09:43 AM
JKM
2018 WK
same here. fixed one with fender washer and tore the other one off. Rattled like a tin can at idle
JKM is offline
post #5 of 5 Old 12-18-2017, 11:34 PM
Chirpz
Chirpz's Avatar
2007 WK
Took mine off a long time ago.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
exhaust , jeep , ratttle , wk
