Issue w/ Factory Radio - JeepForum.com
 1Likes
  • 1 Post By colinzj
post #1 of 8 Old 10-14-2021, 11:48 AM Thread Starter
Billbo1970
2009 WK
I'm having a strange issue with the factory radio: When you turn on the headlights, the main display dims. Not a problem at night, but during daylight hours you can barely read it it's so dim. When you put on the turn signal it brightens up, then goes dim again when the blinker turns off. Turn the headlights off it brightens, turn them off it dims again.
Not sure if this is the exact unit, but it looks like this:
Regards,
Bill
Billbo1970 is offline
post #2 of 8 Old 10-15-2021, 07:43 AM
jeeptorino68
1992 XJ Cherokee
Has the backlight adjustment on the turn signal stalk been working or is inoperable?
Kyle
92 XJ 4.0 HO,AW4, NP242, 30" BFG AT, 1.75 spacer and ZJ coils, double cherokee leaf pack and 2 inch rough country shackles, 2.5 inch dnynomax exhaust, magnaflow cat, front hooks & rear hitch, gas skid, front skid, warn t-case skid, 99+ intake, bored TB
02 KJ Limited, 255 70 16s, front skid, LS/373 gears
jeeptorino68 is offline
post #3 of 8 Old 10-15-2021, 01:21 PM
nwoods
2006 WK
Just sounds like the day/night setting is reversed. You can force that on most vehicles. I don't know how on your radio, but there is a Settings button.....
2006 Jeep WK on 33ís
HAM: KI6FPO
Offroad Photography:
nwoods is offline
post #4 of 8 Old 10-15-2021, 04:34 PM Thread Starter
Billbo1970
2009 WK
@jeeptorino68
The interior light adjustments on the stick work just fine
@nwoods
I don't think that's it because it will brighten up to normal when you put on the turn signal... it's very odd. Sometimes it will stay bright, then suddenly dim itself. Also, it's ONLY the radio, the rest of the dash is just fine!
Regards,
Bill
post #5 of 8 Old 10-30-2021, 05:01 PM Thread Starter
Billbo1970
2009 WK
@jeeptorino68 It appears to be the interior light brightness ring on the turn signal stick. Jiggling that when it dims will USUALLY brighten it back up. I keep it on the 1st click, for full interior brightness. Must be some oxidation or something causing a contact issue there? I can't see any way to take this apart to clean it, is there no way to service it? Is it a PITA to remove & replace this stick?
Regards,
Bill
post #6 of 8 Old 10-31-2021, 09:05 PM
Vertisce21
Sounds like it's time to replace it to me.
Vertisce21 is offline
post #7 of 8 Old 11-05-2021, 12:03 PM
colinzj
2006 WK
Yeah, from those symptoms you're looking at a failed/failing multifunction switch. The upshot is that it did get several revisions across its life to last longer and feel better, and if you go with a current Mopar part it'll probably last you the life of the vehicle and then some. (Some of the aftermarket ones are probably fine too, but once bitten twice shy there. A lot of them have really bizarre stalk action and crappy detents on the dimmer ring.)
The stalks are not designed to be serviceable, and even if you can get it apart and back together, very likely the issue is that the internal contacts are damaged, which isn't something you can really repair.
Easy job. Disconnect the battery and have all your tools on hand and you'll be drinking a cold one in under an hour. Wheel stays on; you only need to remove the column surround and undo a couple screws holding the switch in place.
Just make sure you get one that has controls for your vehicle's equipment — if you've got fogs and/or automatic headlamps, you'll want a version with those controls. More basic stalks do exist for more basic trims. If you're buying through a dealer or Mopar, give 'em your VIN and they can make sure you get the right one.
nwoods likes this.
2014 WK2 Laredo 4x4 3.6L
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L
colinzj is offline
post #8 of 8 Old 11-17-2021, 02:53 PM Thread Starter
Billbo1970
2009 WK
@colinzj Sorry for the late reply, the forum never notified me of your response!!!
Anyway, thanks for the info, I'm glad it's an easy job. I have a base Laredo, no frills... not fogs or auto headlights. According to Rockauto, the part #'s are 5183952AA, 5183952AB, 5183952AC, 5183952AD, 5183952AE, 5183952AF, SW5299. They do not have a Mopar part listed, just WVE whom I've never heard of... anyone familiar with this brand? For some reason the one WITHOUT fog lights is $10 more than the one WITH fog lights?!?! Can I save $10 and get that, knowing it just has a function I won't be able to use?
Regards,
Bill
