Interior Electrical Problem - JeepForum.com
post #1 of 6 Old 10-16-2015, 07:11 AM Thread Starter
LIONJR242
2007 WK
List of issues that started at the same time in my '07:
1) Driver side door controls do not function including front windows, side mirrors, window and door locks.
2) Interior dome light does not function
3) Stereo must be manually shut off after ignition is turned off and key removed
Any ideas?
LIONJR242 is offline
post #2 of 6 Old 10-16-2015, 08:31 AM
sfjacks1
Check the wiring going into the drivers door, I bet you will find a broken wire. It was a all to common problem on the WJ, there will be a broken wire (poss ground) in the boot
sfjacks1 is offline
post #3 of 6 Old 10-16-2015, 02:55 PM
tom19511
2014 WK
Check the fuses and relays...
http://www.wkjeeps.com/wk_fuses.htm
Tom
tom19511 is offline
post #4 of 6 Old 10-19-2015, 09:53 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Any ideas?
Hey LIONJR242,
TSB 08-015-07 may relate to your vehicle:
SUBJECT:
Flash:Sunroof Module, Excessive Ignition Off Draw, Pop In Radio with Ignition Off, Dome
Lamp Flickers And May Not Go Off
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Sunroof Motor Module
with new software.
MODELS:
2006 - 2007 (LE) 300, Touring (International Markets)
2006 - 2007 (LX) 300, Charger, Magnum
2007 (L2) 300 (China)
2006 - 2007 (WK) Grand Cherokee
2006 - 2007 (WH) Grand Cherokee (International Markets)
2006 - 2007 (XK) Commander
2006 - 2007 (XH) Commander (International markets)
2006 - 2007 (DR) Ram truck
SYMPTOM/CONDITION:
Some customers may experience a software issue in the Sunroof Motor Module causing
the Vehicle Communication System (BUS) to stay active after the vehicle is shut down.
This condition can cause any of the following symptoms:
Dead battery after vehicle has not been used for 2 or more days due to excessive
ignition off draw
Popping sound in radio or thumping sound from speaker/subwoofer when operated
with the ignition off. This can occur with the radio off.
Interior lighting flickering or not turning off after the vehicle is shut down.
Please let me know if you have any further questions.
JeepCares is online now
post #5 of 6 Old 12-13-2015, 09:43 AM
BlackRat
2010 WK
did you ever figure out what was causing this problem
my 2010 wk just started having the same problem but i have a few more things not working.
My airbag light is on, my door sensor does not know the door is open or closed. front windows dont work, door locks only work from key fob, i have no heat or air, rear heated seats dont work, and park assist doesnt work but the back up camera does, none of the interior, courtsey, glove box lights work and thats all i have found so far
BlackRat is offline
post #6 of 6 Old 12-15-2015, 08:20 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey BlackRat,
If these conditions are all constant, I would advise you to have the vehicle formally diagnosed at a certified FCA dealership.
electrical issue , ignition , radio
