Inner tie rod replacement - JeepForum.com
 1Likes
  • 1 Post By Raffish
post #1 of 9 Old 10-17-2019, 08:26 PM Thread Starter
JeepN_A_CJ7
JeepN_A_CJ7's Avatar
1980 CJ7
I've never had to change an inner tie rod, but the time has come! Can you replace it without the inner tie rod tool? If so, what standard tools do you need? I tried looking for a write up for this but didn't see one, thanks in advance!
Always Jeepin!
*2007 WK QDII HEMI
*1980 CJ7 4.2L w/FAST FI
Silver WK Club
JeepN_A_CJ7 is offline
post #2 of 9 Old 10-18-2019, 09:32 AM
Raffish
2005 WK
Did mine a few months back. They were super sloppy and it helped reduce clunking over bumps.
You will need an inner tie rod tool, I borrowed one from a parts store.
The hardest part was crimping the boot ear clamp just because there's not much room, you'll need side crimpers.
I used cheap RA parts that have been fine so far.
JeepN_A_CJ7 likes this.
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, MBRP SS, 250xxxkms
Raffish is offline
post #3 of 9 Old 10-18-2019, 03:06 PM Thread Starter
JeepN_A_CJ7
1980 CJ7
Would I be able to use large zip ties instead of the clamps, I find those type of clamps to be a pain and not worth the effort?
Always Jeepin!
*2007 WK QDII HEMI
Silver WK Club
post #4 of 9 Old 10-18-2019, 03:13 PM
Windexer
When you say sloppy were they actually worn in the ball/cup area, or just very floppy when you removed the outer TRE? I've got mine apart at the moment and the inners "seem" ok but they do move very freely through their range of motion.
2005 WK Limited Hemi, 2" OME lift, header back exhaust, 245/75/R17 MT, Superchips tuned, Roof rack
Windexer is offline
post #5 of 9 Old 10-19-2019, 06:40 PM
Raffish
2005 WK
[QUOTE=JeepN_A_CJ7;40770695]Would I be able to use large zip ties instead of the clamps, I find those type of clamps to be a pain and not worth the effort?
Probably..? Not sure how you'd get enough tension though.. don't think there's even enough room to put pliers in it and twist...
I busted the ear clamp that came with it and had to grab another. Parts stores should carry them..
Raffish is offline
post #6 of 9 Old 10-19-2019, 06:42 PM
Raffish
2005 WK
When you say sloppy were they actually worn in the ball/cup area, or just very floppy when you removed the outer TRE? I've got mine apart at the moment and the inners "seem" ok but they do move very freely through their range of motion.[/QUOTE]
I didn't notice any real wear it damage,just super floppy.. like lift it up and let go and it drops immediately. New ones are stiff
Raffish is offline
post #7 of 9 Old 10-19-2019, 07:49 PM
acabtp
2005 WK
seems like the mopar parts for these are discontinued now
did you guys put new boots? if they came with the kits, which brands did you use?
'05 WK Limited 5.7 Hemi
acabtp is offline
post #8 of 9 Old 10-19-2019, 07:52 PM
Rtbrjason
Rtbrjason's Avatar
2008 WK
Did both of mine recently. Used a large pipe wrench. One of the boots crimped on no problem and the other didn’t work out. I tried a zip tie twice and it failed in short order both times. Ended up using a regular worm gear hose clamp and it’s held up fine. Used an extension and universal with an 8mm socket to tighten it down.
Rtbrjason is offline
post #9 of 9 Old 10-21-2019, 03:18 PM Thread Starter
JeepN_A_CJ7
1980 CJ7
I ordered the cheapest set of inner tie rods from Amazon that came with boots ($23) to get the boots, I couldn't find them sold separately anywhere so I went with that. Yeah, for some reason just buying the new boots by themselves wasn't easy to find.
Forgot to mention that I'm installing Jeeperf's inner's and outer's so I won't have to deal with them ever again.
Always Jeepin!
*2007 WK QDII HEMI
Silver WK Club
