Inner tie rod end. - JeepForum.com
post #1 of 11 Old 04-05-2019, 02:20 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Inner tie rod end.
I have another thread going where I needed some advice on removing a wheel bearing but rather than continue to add to that I figured I’d start this thread regarding the inner tie rod.
I think I can get the inner boot clamp off but not sure how I’d get a clamping tool in there to put a new clamp on. The new inner tie rods came with just a clamp, no new boot so I don’t want to destroy the boot in the process. I’ve turned the wheel to one side but access isn’t really any better. Has anyone who has done this job on a wk able to give some input? I’m hoping I don’t have to pull the whole steering rack to do this job right.
05D338B8-B8D2-4432-87A3-991AADF1387F_1554495580832.jpg   8522F6B8-7072-46AF-BC2D-127C19BAF7A6_1554495598275.jpg
Rtbrjason is offline
post #2 of 11 Old 04-05-2019, 08:22 PM
BadExample
BadExample's Avatar
2006 WK
Looks to me like you just squeeze that clamp down with channel locks (or other parallel jaw pliers) and slide it back with the boot. Or slide it out and off the boot and leave it there to re-use. I don't think you want to remove it.
BTW: That's an outer end, there is no tie rod or inner end with R&P steering.
CJ5 we don't talk about, 58 Willys CJ-3B gone
79 J-10 gone, 99 GC WJ murdered and gone
2006 GC WK
BadExample is offline
post #3 of 11 Old 04-05-2019, 09:09 PM
SteveROntario
I had a garage do mine and they had to call in a plumber to clamp it. He used a PEX side jaw crimper similar to this:
https://www.amazon.com/Oetiker-2000-.../dp/B07PNK7W3C
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #4 of 11 Old 04-05-2019, 10:27 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
I'm pretty sure I can get the boot off, I just don't see a way to put the new clamp back on with the inner tie rod end. I did purchase the inner and outer for both sides so I'm not sure what you mean. I'm planning to leave the outer on if possible so I can make sure the new inner and outer end up being as close as possible to the ones that come out.
post #5 of 11 Old 04-05-2019, 10:28 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Interesting. I'm not sure there is even room to get that in there though.
post #6 of 11 Old 04-06-2019, 06:51 AM
BadExample
BadExample's Avatar
2006 WK
Never mind me
2006 GC WK
post #7 of 11 Old 04-06-2019, 01:24 PM
Raffish
2005 WK
I just grabbed these..
https://www.canadiantire.ca/en/pdp/c...4567p.html#srp
hope they fit!!
will update shortly..
They worked..
I put the crimp at the bottom where there's a bit more room.
They really don't take too much force to crimp.. (don't ask)
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, 250xxxkms
Raffish is offline
post #8 of 11 Old 04-06-2019, 02:36 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Great. Anxious to hear if these worked. I’m also considering using a regular radiator hose clamp. Looks like if it’s positioned right, I might be able to get a screw driver on it from underneath.
http://www.canadiantire.ca/en/pdp/ch...4567p.html#srp
hope they fit!!
post #9 of 11 Old 04-06-2019, 02:42 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Also wondering if you used an inner tie rod tool to remove them or if you were able to turn them off with a wrench or something else?
post #10 of 11 Old 04-06-2019, 04:00 PM
Raffish
2005 WK
Haha I borrowed one from a parts store. (But there's room on passenger side at least for a wrench)
It went up to 1 7/16".
The offending part on my ride was 1 5/8".
Only thing I had that big was vice grips, did the trick.
New part was 1 1/2" so I may have modified the borrowed tool a touch.
Torqued to 80'lbs. (I cant seem to find anything whatsoever in the FSM I have for the inners??)
New inner CV clamp, used that tool ^^^.
Never-seize on the threads, jam-nut (60'lbs) on first.
70'lbs for the TRE b-joint.
Raffish is offline
post #11 of 11 Old 04-06-2019, 04:07 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
I pulled the boot and think a pipe wrench might work. Trying to pull it off all connected with the outer so I can match up the size for the new inner/outer. I haven’t seen an inner tie rod tool in person but looking under the boot it’s not clear what it would grab on to. I tried some channel locks but they’re too small to grab it well enough and get decent torque.
Larger than stock ball joint on a tie rod end? Cutlass327 Jeep CJ Forum 7 12-12-2018 02:23 PM
Did I just overfill a tie rod end with grease? AVR2 WJ Grand Cherokee Forum 3 11-26-2018 09:29 AM
HD y-link tie rod end help Psyclops YJ Wrangler Technical Forum 16 04-08-2018 02:44 PM
Finding a Bad Tie Rod BorderWalker ZJ Grand Cherokee Forum 4 11-26-2017 01:26 PM
