Injector stuck! How do I use this tool? - JeepForum.com
 4Likes
  • 3 Post By badgerwithhands
  • 1 Post By underscore
post #1 of 15 Old 05-29-2020, 07:11 PM Thread Starter
HankyD
Hi peeps,
It's been several months since I've been on, I hope everyone's staying safe and healthy.
I have a blown injector seal. I have all the parts needed but can't get the injector out. It's stuck... like really stuck.
The injector is on the driver's side bank. It's the middle injector (I don't know what number that makes it on this application).
I purchased a tool off amazon but...it sucks. lol I am pretty sure this kit doesn't come with a particular fastener which is required to render the "hammer action" need to loosen the injector.
The fastener (that is missing) should screw in to the end of the tool.
Here is the link to the tool that I purchased off of amazon.
[URL="https://www.amazon.ca/gp/product/B06WLR5MXL/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1"]
Anyway!
Am I wrong here?
Does anyone know how to use this tool? What am I missing here?
Thanks again,
HankyD
HankyD is offline
post #2 of 15 Old 05-30-2020, 12:10 AM
rokrau
2008 WK
It’s supposed to be used with a slide hammer. Some kits come with that but yours didn’t. I’d send it back, get a different one or blow the injector out as some people do. There are videos on how to do it.
Good luck.
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #3 of 15 Old 05-30-2020, 05:05 AM
RCS1300
2005 WK
These worked for me. They are called Knipex connector pliers with plastic jaw inserts. Remember that it is only O rings that are holding in the injector in a gasoline engine. You did not mention if you had a diesel engine. If diesel, I have no idea how to get an injector out.
https://www.homedepot.com/p/KNIPEX-C...-250/207015696
RCS1300 is offline
post #4 of 15 Old 05-30-2020, 02:14 PM Thread Starter
HankyD
Sorry RSC, it's a CRD.
RokRau, Yea, I might just blow it out I guess?
Have you tried this out yourself btw?
I already have the hold down bolt out and the metal bracket out, is that a big deal?
Also,
3000rpm sustained is what's needed?
Any other tips while I do this is appreciated.
Thanks again!
HankyD is offline
post #5 of 15 Old 05-30-2020, 03:23 PM
underscore
2007 WK
I've had a couple really gunked up ones, even with the engine cold I've always been able to slowly wiggle it loose and pop it out. What I do is remove everything and spray some carb cleaner around all the gunk, then put the hold down clamp back in place and pry against the clamp to get the injector to rotate. I keep wiggling it back and forth and adding carb cleaner until the cleaner has worked in enough and I can pull the injector out.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #6 of 15 Old 05-30-2020, 09:03 PM
rokrau
2008 WK
Not on my current car but on a similar Mercedes engine years back. Some others use the same injectors iirc. I am about to get to this however and plan to follow what they do at some shops. Loosen and tighten the hold-down bolts at 2500rpm a dozen times to loosen the suckers up. I’ll also soak the things in gunk-off.
I’ll do one bank at a time.
Best of luck
rokrau is offline
post #7 of 15 Old 05-31-2020, 09:20 PM Thread Starter
HankyD
Thanks, I give it a try!
HankyD is offline
post #8 of 15 Old 06-01-2020, 11:07 AM
badgerwithhands
2007 WK
The threads are M14x1.5, IIRC. I made my own on-the-fly slide hammer (literally scrap pipe is the "hammer") to get one out. I had both of my slide hammers stolen a while back and haven't bought a new one. I've re-welded the nut since then. I was in a rush. Only a little judgement, please.
SillyDude, underscore and 2005JGC like this.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #9 of 15 Old 06-03-2020, 09:41 PM
Chirpz
Chirpz's Avatar
2007 WK
If you have not already, check out my DIY guide for this job....
https://www.jeepforum.com/forum/f67/...l#post38959737
I had one that was stuck really bad.... after doing all the prep work mentioned in my guide, I blew it out with engine compression.... worked great... no damage to the injector.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #10 of 15 Old 06-04-2020, 11:32 AM
Sosruko
Sosruko's Avatar
2007 WK
I am lucky. I also had to do this repair, but my injector was not stuck. One little wiggle and it lifted right out!
I had removed the foam blocks long ago. I also have a sensitive nose and noticed the quick puffs of diesel at idle... The Black Death has barely started.
Chirpz how-to once again made my life easier!
2007 WK CRD Limited 4X4, QDII, GDE EcoTune, 245/70R17 on stock rims, OEM Tow Hitch
Sosruko is offline
post #11 of 15 Old 06-05-2020, 05:57 PM
johnniebravo
2008 WK
I know I am late to the party here and this may already be solved, but there is an injector puller that fits the OM642 injectors. It is cheap too. I purchased on late last year and was stunned at how easy it made injector seal jobs. Costs about $22 dollars.
https://www.amazon.com/ABN-Diesel-In...1401301&sr=8-1
ABN-3124
Brand Auto Body Now
Manufacturer ABN
MPN3124
Base SKU ABN-3124
UPC811498033124
2008 CRD GC
johnniebravo is offline
post #12 of 15 Old 06-06-2020, 10:21 PM Thread Starter
HankyD
Okay so now, after I reinstalled my injector line to the main fuel rail, it sprays out diesel when I turn on my jeep. smh.
Obviously, something isn't adding up.
Is there a special methodology when reattaching/screwing this line to the fuel rail? Do I have to screw it in-concert with screwing in the injector portion of the line?
Yes, it was tight upon re-tightening it.
The thread is still intact so no, I didn't cross thread anything.
This is the second time it has done this now.
Thanks again!
HankyD is offline
post #13 of 15 Old 06-07-2020, 12:20 AM
underscore
2007 WK
Check the matching surfaces of the flanges for damage and debris. I had a couple that weeped and needed a little extra tightening, they're pretty awkward to work with so it's hard to get them really tight.
badgerwithhands likes this.
post #14 of 15 Old 06-07-2020, 06:50 AM
badgerwithhands
2007 WK
Definitely a plus 1 on weeping and needing a little extra tightening.
post #15 of 15 Old 06-08-2020, 10:50 PM Thread Starter
HankyD
Okay guys, I'll give it a try.
I'll keep you updated.
thanks again for the support!
HankyD is offline
