If I don't want to do the pinch weld... - JeepForum.com
 1Likes
  • 1 Post By Vertisce21
post #1 of 7 Old 07-21-2021, 03:35 PM Thread Starter
goldcrown4
2005 WK
A couple years ago, I installed the 2" Daystar lift, Bilstein 4600/5100, 1.5" wheel spacers, and new Kumho Road Venture AT51's, in size P265/70/17. Until they wore down enough, a max left turn would cause very light rubbing and I never got around to doing the pinch-weld mod. I am about to replace the Titan wheel spacers with SpiderTrax, 1.5".
I will need new tires in the late Fall/early Winter to be prepared for another Wisconsin winter. My question is, should I decrease the width or the height of the tire by one increment to prevent the rub? I'm thinking the height only??? and go with P265/65/17. Am I right? I know it can be tire dependent, but I really liked the overall performance of the Kumho AT51's so it's likely I'll get those again.
goldcrown4 is offline
post #2 of 7 Old 07-21-2021, 09:28 PM
Planetcat
2010 WK
I ran 255/70r17’s for a while. Even though I had the pinch weld mod, I didn’t need it for those all terrains. That size is getting harder to find these days though, which us why I went to 265/70r17.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #3 of 7 Old 07-21-2021, 10:55 PM
Vertisce21
The pinch weld mod is super easy. Worth doing. Just do it and save yourself all the headache of worn down tires later.
nwoods likes this.
Vertisce21 is offline
post #4 of 7 Old 07-22-2021, 07:55 AM
badgerwithhands
2007 WK
Also, do you want passenger tires versus light truck tires? LT tires are usually a little bit "larger" due to tread.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #5 of 7 Old 07-22-2021, 10:05 AM Thread Starter
goldcrown4
2005 WK
I'd prefer the LT's... I'm just not off road enough to appreciate the difference I guess. I read many that have LT's, but still drive pavement 99% of the time, simply deflate them to around 26 -30 psi to keep their tooth fillings from falling out. I know the pinch weld is considerably easy and I just need to make the time to get it done, but there's a chance I'll be selling this Jeep within the next year and it needs to have new tires before the Winter.
post #6 of 7 Old 07-23-2021, 11:35 AM
nwoods
2006 WK
Why NOT do the pinch weld mod? It takes about 30 minutes to do both sides. It helps if you buy a $40 angle grinder from Harbor Freight to cut it into short sections, which makes pounding it flat a bit easier, but its all very easy to do. Literally just hitting it with a hammer and then spray painting it with an under carriage primer/paint spray
2006 Jeep WK on 33ís
HAM: KI6FPO
Offroad Photography:
nwoods is offline
post #7 of 7 Old 07-24-2021, 07:24 AM
Mainsail
2005 WK
265/65-17 should fit.
No lift, no pinch weld mod, no spacers, and AEV's WK wheels.
Poor grammar is something up with which I shall not put.
Mainsail is offline
