How can I adjust the TPMS range or settings? - JeepForum.com
post #1 of 5 Old 11-02-2017, 11:54 AM Thread Starter
Tango.
How can I adjust my TPMS tire pressure measure system, so when I run different tire pressures the alarm doesn't go off?
I know on the dodge ram and can adjust the setting and that 20% tolerance range with the scanner and the 4 digit pin, but how do I do it on the Jeep?
Life is hard-John Wayne
Tango. is offline
post #2 of 5 Old 11-02-2017, 12:48 PM
keggles
keggles's Avatar
2008 WK
You will need to get a tuner in order to hook up to the ODBII sensor and make changes or turn off the TPMS alarm. DiabloSport/SuperChips have them and I am not 100% if the HPTuner does it as well.
People say I'm difficult and sometimes that's a badge of honour.
08 WK 5.7 Hemi | Volant CAI | Gibson 3" Catback | Sonnax Line Booster | BT Catch Can
06 WK 4.7 - RIP
Silver WK Club #63
keggles is offline
post #3 of 5 Old 11-03-2017, 10:32 PM
Clarkyau
2006 WK
I did it on my CRD with Autoenginuity. took a bit of fiddling but I was able to lower the threshold to 10psi. If I remember correctly the setting was in the front control module.
http://plus.google.com/u/0/+DownunderJeep/posts/p/pub
Clarkyau is offline
post #4 of 5 Old 11-05-2017, 11:14 AM
IlanLCD
2008 WK
I used flashpaq, min. set to 24 PSI, the lowest possible.
2008 WK, limited, QTII OX locker, 4.7 super chipped, free flow muffler, K&N filter, modified lift
IlanLCD is offline
post #5 of 5 Old 11-29-2017, 12:26 PM
Fremen
2008 WK
I used https://appcar-diagfca.com/en/ and disabled it completely for my winter tires
Fremen is offline
