JeepForum.com (https://www.jeepforum.com/forum/)
-   WK Grand Cherokee & XK Commander Forum (https://www.jeepforum.com/forum/f67/)
-   -   How can I adjust the TPMS range or settings? (https://www.jeepforum.com/forum/f67/how-can-i-adjust-tpms-range-settings-4191058/)
Tango. 11-02-2017 11:54 AM
How can I adjust my TPMS tire pressure measure system, so when I run different tire pressures the alarm doesn't go off?
I know on the dodge ram and can adjust the setting and that 20% tolerance range with the scanner and the 4 digit pin, but how do I do it on the Jeep?
keggles 11-02-2017 12:48 PM
You will need to get a tuner in order to hook up to the ODBII sensor and make changes or turn off the TPMS alarm. DiabloSport/SuperChips have them and I am not 100% if the HPTuner does it as well.
Clarkyau 11-03-2017 10:32 PM
I did it on my CRD with Autoenginuity. took a bit of fiddling but I was able to lower the threshold to 10psi. If I remember correctly the setting was in the front control module.
IlanLCD 11-05-2017 11:14 AM
I used flashpaq, min. set to 24 PSI, the lowest possible.
Fremen 11-29-2017 12:26 PM
I used https://appcar-diagfca.com/en/ and disabled it completely for my winter tires
The time now is 11:25 PM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
