Highway Speed Hum - JeepForum.com
post #1 of 3 Old 06-07-2015, 04:40 PM Thread Starter
ConcreteCanoe
2005 WK
Highway Speed Hum
I have a 2005 WK with the 3.7 that has about 175k on her. Within the last few weeks it has started to hum and vibrate around 50 or so mph. I can feel the vibration in the gas pedal and in the floor boards as well as very slightly on the steering wheel. As soon as I let off the gas, the vibration and hum returns. The hubs up front feel tight and all the u-joints feel tight, except for a little bit of vertical play at the rear u-joint of the transfer case. The front struts are shot and are soon to be replaced and I'm not sure if their lack of ability to be a damper is causing it. I can also move the transfer case up about 3-4 inches by hand so is it possible that the bushings and mounts for the transfer case is shot? I'm pretty stumped. Thanks
ConcreteCanoe is offline
post #2 of 3 Old 06-07-2015, 04:42 PM Thread Starter
ConcreteCanoe
2005 WK
Edit: the vibration and hum stop once I take my foot off the gas.
post #3 of 3 Old 06-07-2015, 09:11 PM
06WKHEMI
06WKHEMI's Avatar
2006 WK
Sounds like a pinion bearing to me that was what i had going on when my rear went bad
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
transfer case , vibration , vibration on acceleration
