"Hidden" remote start on my 2008 Grand Cherokee not working anymore - JeepForum.com
post #1 of 15 Old 11-08-2019, 07:40 PM Thread Starter
JeffSearls
I'm looking for a little direction here. My stock "hidden" remote start isn't working anymore. It was working fine, then one day, nothing. No new work was done on the vehicle. All the threads say to check the hood position plunger switch, but my Jeep doesn't have one. I can NOT find the cause of the remote start not working. Any ideas?
JeffSearls is offline
post #2 of 15 Old 11-09-2019, 12:36 AM
underscore
2007 WK
Low fuel or a CEL will cause it to not work. There is a hood switch on all WKs if my memory serves, I've never noticed one either so it must be tucked away a bit.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #3 of 15 Old 11-09-2019, 04:58 AM Thread Starter
JeffSearls
Thanks for those ideas but I have over half a tank of fuel and no CEL. I read somewhere that the hood safety switch is built into the hood latch, but there is only the cable going into the latch, no wiring. I'm going crazy here! Lol!
post #4 of 15 Old 11-09-2019, 08:47 AM
Rtbrjason
Rtbrjason's Avatar
2008 WK
My 08 has the hood switch by the driver side fender, around the half way point. Possible it got dislodged and is dangling down somewhere?
Rtbrjason is offline
post #5 of 15 Old 11-09-2019, 10:31 AM Thread Starter
JeffSearls
Thanks for that! When you said halfway down, by the fender..... is it along the hood rail by the fender? Is it a plunger switch?
post #6 of 15 Old 11-09-2019, 10:38 AM
Rtbrjason
Rtbrjason's Avatar
2008 WK
Yes to both. Closer to the battery.
post #7 of 15 Old 11-12-2019, 10:45 AM
Xmind
2007 WK
Interesting. Is this something for just 2008 or was it on certain trims like the Overland or something? Not OP, but my 2007 Laredo definitely doesn't have this.
'07 GC CRD QDII
Xmind is offline
post #8 of 15 Old 11-13-2019, 09:02 AM Thread Starter
JeffSearls
The 2008 Jeep Grand Cherokee has a factory remote start built into the remote. If you press the Lock button 3x followed by the Unlock button 3x, the Jeep starts. Mine doesn't do that anymore. All the threads say to check the fuel level, Check Engine Light and the hood position switch because if there is a problem with any of these things, the Jeep won't start. I have a full tank of fuel, NO CEL on and I can't find the hood position switch. But,..... Now that my upper ball joint broke on Sunday while I was driving, my remote start is the last of my worries!!
post #9 of 15 Old 11-13-2019, 09:04 AM Thread Starter
JeffSearls
Thanks for the photo....... I definately do NOT have a button like that under my hood!
post #10 of 15 Old 11-13-2019, 09:04 AM
Rtbrjason
Rtbrjason's Avatar
2008 WK
My remote has an actual start button. Before the ignition recall, you pushed it twice to start. After the recall I seem to have to push it twice, pause and then twice again.
post #11 of 15 Old 11-14-2019, 12:47 PM
Grinmaul
2008 WK
My 08 has the factory remote start, its own button on the Mercedes style key you press twice to start, and has the hood switch pictured above.
that press unlock and lock 3 times sounds like an aftermarket unit install that is wired in to look for that sequence of lock presses to trigger, never heard of a factory unit like that, maybe a dealer install aftermarket unit?
2 2008.5 WK CRD's, 2005 WK Limited 5.7
Grinmaul is offline
post #12 of 15 Old 11-15-2019, 12:00 AM
2007laredowk
2006 WK
Heard that lock/unlock combo before, it's an aftermarket unit, if you do some digging you will probably find the manufacturer. Factory remote starts, in general, have a dedicated button in the key fob with the circled arrow.
2007laredowk is offline
post #13 of 15 Old 11-15-2019, 01:49 PM
underscore
2007 WK
There is a dealer-installed remote start module that uses the standard fob and a combo of button presses but if I remember right the sequence is different from that.
post #14 of 15 Old 11-16-2019, 01:29 AM
2007laredowk
2006 WK
Originally Posted by underscore View Post
dealer-installed remote start module that uses the standard fob and a combo of button presses.
Didn't know about those, the ones I've seen offered as a Mopar accessory come with updated fobs with the dedicated circled arrow button.
post #15 of 15 Old 11-18-2019, 08:54 AM
Arneb04
Arneb04's Avatar
2008 WK
This sounds like aftermarket, in which case there may be a relay box under the drivers side dash back by the brake pedal. That's typically where I've seen things installed. Wires may have corroded over time, it may have been kicked accidentally. Even an aftermarket unit should have a hood position sensor somewhere. Problem is, unlike the units that come standard on WKs, the plungers are not a sensor of any kind, they are a binary pin designed to complete a ground circuit and that's it. If it has one of these and you can't find it, you can't fix it.
Arneb04 is offline
