HID/LED Headlight Project - Page 11 - JeepForum.com
 5Likes
post #151 of 162 Old 12-04-2016, 05:57 PM
Yooshaw
2007 WK
Just tap the high beam, polarity doesn't matter for the solenoid. Does you low beam stay on with the high beam? US they do but don't know of on export models.
Yooshaw is offline
post #152 of 162 Old 12-04-2016, 06:49 PM
kryton
Cool thanks. Yep export low stays on as well
kryton is offline
post #153 of 162 Old 01-31-2017, 09:30 PM
jediknight
2008 WK
I'm currently stuck with an issue here.
The loom inside the lamp that links balast to bulb is damaged. I've read the whole thread, but I can't seem to find the procedure to get the loom out. I have the replacement loom in front of me, but can't figure a way to remove the old one and replace with the new one. It looks like it is fitted before sealing the plastic cover and front lens together.
How is the baking procedure with these?
Pre-heat @ 250F
Turn off oven then on a cookie pan for 10 min?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #154 of 162 Old 01-31-2017, 09:56 PM
jediknight
2008 WK
Got it.
Follow my procedure up.
post #155 of 162 Old 02-01-2017, 05:54 AM Thread Starter
08zombie
08zombie's Avatar
2008 WK
^^^^^ Glad you got them open!
Leaving the gym last night I snapped a quick picture of the beam against a wall ~20-25ft away. Unfortunately it was with my potato but a picture nonetheless. You can see the flare on the far edges of the beam right before the drop off. Everything is still running smoothly. Can't really see the color flicker it has at this distance.
Check My Threads For These Builds:
WK LED Headlight Quad Retrofit
WK Morimoto LED Foglights
08zombie is offline
post #156 of 162 Old 02-02-2017, 02:59 PM
08rubie1
so to sum this awesome job up you took ur stock non hid lens off picked up a 08/09 hid housing with lens added a high beam projector and took ur stock 07 lens and stuck it on the 08/09 housing?
lol good work... i mainly ask because i would like to take a 08/09 projector housing and massage these in https://www.google.com/search?q=Pors...mKj42GDmB2hHM:
08rubie1 is offline
post #157 of 162 Old 02-03-2017, 07:46 PM Thread Starter
08zombie
08zombie's Avatar
2008 WK
The Panamera shroud would look good. Might be tough to squeeze in the high beam reflector. It's one of the larger shrouds. I'm guessing you're wanting to use halos too.
I removed my 2008 Halogen headlights. Bought a set of 2008 HID replica lights and swapped out the low beam projectors. While I was in there I added dedicated projectors for the high beams.
08zombie is offline
post #158 of 162 Old 05-01-2017, 01:29 PM Thread Starter
08zombie
08zombie's Avatar
2008 WK
The headlights and fog lights made it through winter without any issues! Still going strong and I'm very proud of them.
Like I said before I have a set of OEM ones open but don't have any idea what I want to do with them yet... Ultimately I'd like to build them and sell them. I just need someone's ideas!!
08zombie is offline
post #159 of 162 Old 05-01-2017, 02:07 PM
jediknight
2008 WK
Hey! I just noticed that you have projectors for the DRL/High beams?
post #160 of 162 Old 05-01-2017, 02:20 PM Thread Starter
08zombie
08zombie's Avatar
2008 WK
Yup the high beam is a dedicated H9 halogen high beam projector. They came out of a Kia Cadenza courtesy of another member here. The DRL/turn signal is still the 3157 bulb.
08zombie is offline
post #161 of 162 Old 05-01-2017, 02:24 PM
jediknight
2008 WK
Very clever haha
What parameters did you use to line up your HID?
I feel mine are shooting everywhere. I'd hate blinding people crossing over...
post #162 of 162 Old 05-01-2017, 02:29 PM Thread Starter
08zombie
08zombie's Avatar
2008 WK
Very clever haha
What I roughly used was: for every 25ft away from the headlights the beam drops 2-3in. The steps should be the same width apart as the projectors are from eachother (center to center). Pull up to a wall and take a few pictures.
08zombie is offline
headlight , hid , led , retrofit , wk
