Grand WK antifreeze leak - JeepForum.com
post #1 of 11 Old 09-24-2014, 06:12 AM Thread Starter
cristian_87
2007 WK
Hello guys !
My name is Cristian and I'm from Romania. I'm posting on this forum because I have a problem and nobody knows how to solve it.
My rig is a 2007 Grand WK 3.0 diesel Mercedes OM642.980 engine.
I have a coolant leak . It is situated near the starter. I took out the starter , the left engine mounting and lowered the front diff. It is a hole in the engine block and the problem is that whenever the pressure builds up in the coolant circuit , it start dripping. The loss is about 1 L for 1000 km. I dont't know if this a technological plug hole or something else should be there. I was considering to plug it but I don't want to blow up on the road.
I will attach some pictures. Also if you have some diagrams of this engine, it would be helpful. I tried to search in the GC service manual and also in the Mercedes one but with no luck.
Thank you in advance for your answers !
cristian_87 is offline
post #2 of 11 Old 09-25-2014, 12:03 AM Thread Starter
cristian_87
2007 WK
hey..
any opinion is welcomed ... I really don't know what to do ...
post #3 of 11 Old 09-25-2014, 03:38 AM Thread Starter
cristian_87
2007 WK
this is the hole in question..I don't know it's purpose...could someone help pls ?
post #4 of 11 Old 09-25-2014, 07:36 AM Thread Starter
cristian_87
2007 WK
I found out that the hole is for draining the V - it's a known problem for oil leaking but not for antifreeze
https://www.youtube.com/watch?v=TJ9T1C0UMAE
post #5 of 11 Old 09-25-2014, 11:58 AM
caulk04
2008 WK
Interesting, neat that they incorporated a valley drain into the block.
I'd think surely there is coolant leaking into the V and it's draining there, rather than coming from somewhere inside the block.
That's all the more help I am, I know next to nothing about this engine.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #6 of 11 Old 09-25-2014, 12:03 PM
tom19511
2014 WK
Have you considered the water pump? Maybe blowing back under pressure?
Tom
tom19511 is offline
post #7 of 11 Old 09-25-2014, 08:41 PM
Tango.
That looks like an oil leak.
Tango. is offline
post #8 of 11 Old 09-26-2014, 12:06 AM Thread Starter
cristian_87
2007 WK
i know it looks like oil but in some pictures you can see it's red...and also the drops that are coming threw the hole are red..I want to look in the V but I cannot replicate the drops unless I rev up the engine and heat it really well..
so I have to make room in the V but also keep the engine working ) I will keep you informed
post #9 of 11 Old 09-26-2014, 07:50 PM
Tango.
Is it transmission fluid?... that is red. That looks like oil to me... not antifreese which vaporizes.
Tango. is offline
post #10 of 11 Old 01-18-2020, 03:08 PM
acdc
acdc's Avatar
This is from oil cooler seals.
I have the same problem
acdc is offline
post #11 of 11 Old 01-18-2020, 05:14 PM
3Recon
2009 WK
wouldn't doing a pressure check on system show it.? pump it up to cap/system pressure it'll show it. not every one has a coolant pressure tester. hand pump would work just needs to get up to cap pressure a couples higher and hold (a cap or something that can seal system) good luck
3Recon is offline
