Gazillion codes - JeepForum.com
post #1 of 6 Old 07-03-2019, 07:27 PM Thread Starter
petzlkong
2007 WK
Gazillion codes
New to WK CRD 3.0 2007 Laredo world. Got it for fun not long ago but now the fun is over. Thunder bolt and oil pressure with engine light. When i look over the codes, i got all those (way to many) codes. Here it comes p0243,p0489,p0652,p0674,5,6,p0676,p2008,p2453,p003 1,004,0100,0471,p03b,p0671,72,73,p0700,p0743,p1685 ,p2264. Look on many forums, some says wire loom, others pcm. Can a wire loom gives that many codes or pcm. Look at wires and only found 1 broken wire. Sometimes more codes appears or disappears. Anybody had that kind of problems or am i the only lucky one.
Thanks for any help because the lighter fix isn't far away.
petzlkong is offline
post #2 of 6 Old 07-04-2019, 12:57 AM
rokrau
2008 WK
Alternator or dead battery.
Wire rubbing in on hot AC line on driver side.
Some of the codes are glow plugs and module but if they all appeared one day out of the blue I’d check these two things first.
Good luck
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #3 of 6 Old 07-16-2019, 08:12 PM Thread Starter
petzlkong
2007 WK
Looks like it's the wire harness over the swirl motor that got burned by that oil. I will do the fix this weekend and come back with more info.
post #4 of 6 Old 07-16-2019, 08:45 PM Thread Starter
petzlkong
2007 WK
Wire harness over swirl motor.
post #5 of 6 Old 07-17-2019, 01:08 AM
rokrau
2008 WK
Weird perspective in that photo. Looks like it’s one the driver side. The swirl motor is on the passenger side. In any case, looks like you found the problem and can fix it.
Good luck and let us know the resolution!
rokrau is offline
post #6 of 6 Old 07-17-2019, 07:05 AM
BadExample
BadExample's Avatar
2006 WK
Just be sure and get good splices and a very good crimper (if using the crimp type). You'll want those to be sealed very well. I want to say water tight, but maybe oil tight would be more appropriate Good luck on the repair!
CJ5 we don't talk about, 58 Willys CJ-3B gone
79 J-10 gone, 99 GC WJ murdered and gone
2006 GC WK
BadExample is offline
