Front Tire digging into fender well -Commander - JeepForum.com
post #1 of 7 Old 11-26-2019, 03:30 PM Thread Starter
gargoyle91
I've got a 06 Commander with the 4" lift How do you keep the front tires from digging into that plastic covering on the inside underneath of the fender well ? Digging into it Behind the front wheels .
gargoyle91 is offline
post #2 of 7 Old 11-26-2019, 08:06 PM
SteveROntario
Research the "Pinch Weld" mod. There are some options on dealing with it.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #3 of 7 Old 11-26-2019, 09:55 PM
2005JGC
2005JGC's Avatar
2005 WK
What size are your tires?
Ultimately I hacked up both of my front splash shields, using heat, a cut off wheel and patience I shaped them, drilled some holes and used some reusable push clips to attach the cut up sections. It doesn't do as well to protect under the hood, but its WAY better than nothing. At some point, the tires is just too much for the space that was made to house a 29" tire.
I have been wanting to create a sheet metal replacement, its just not been super high on the priority list.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #4 of 7 Old 11-26-2019, 10:17 PM
underscore
2007 WK
That looks like the front edge behind the bumper? I trimmed the ends off mine when I trimmed my bumper, as I was having the same issue.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #5 of 7 Old 11-27-2019, 10:15 AM Thread Starter
gargoyle91
285/70 R17 is the size I have now
post #6 of 7 Old 11-27-2019, 10:17 AM Thread Starter
gargoyle91
Actully it's the back of the fender well guess I got to find the sweet spot and cut them to that point
post #7 of 7 Old 11-27-2019, 11:05 AM
2005JGC
2005JGC's Avatar
2005 WK
Yeah, 285/70 is a pretty big tire. It is what I am running. You do need to look into what SteveROntario suggested with the pinch weld mod. Mine are pounded flat. I intend to cut that portion out and plate it over a little further back, but for now the sledge got it far enough out of the way.
2005JGC is offline
