Front suspension reinstall - JeepForum.com
 1Likes
  • 1 Post By SteveROntario
post #1 of 11 Old 05-25-2019, 12:09 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
I’m finally getting my front suspension back together after having removed it, grinding any rust, painting etc and replacing everything. Mevotech upper/lower control arms, moog inner/outer tie rods, links, bushings and strut hardware. Struts are 4600s with OME MD springs.
I had a heck of a time getting the knuckle back in and I’m not loving how the upper ball joint is looking after finally getting it into the knuckle. Nothing is tightened down all the way yet. I had previously had the knuckle off before replacing everything and it went back on fine as I was able to jack up the LCA. Now, when I try to jack up the LCA, the whole Jeep is lifting even with the front LCA bolt loose. I suspect it is due to the new stiffer springs. I did manage to get everything connected but I’m worried about damaging new ball joints. I’m also going to have to jack the front end up considerably higher to get the wheels back on. The upper control arm is down pretty far. Does this seem normal? Do the pics worry anyone?
CFFF1CBE-A178-4509-9F93-C462E87A1468_1558807718768.jpg   33F90BAC-59AE-4478-875C-F510F2606954_1558807732031.jpg   CE3BA8C2-C5A5-43B1-815D-87C3CD42E6AE_1558807743516.jpg
Rtbrjason is offline
post #2 of 11 Old 05-25-2019, 04:58 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Removed the clevis bolt and the lower control arm moved fine. Now I can’t remember if I had that out last time I put the knuckle on or not. The top ball joints are still pretty squished. Hopefully it works out okay.
post #3 of 11 Old 05-25-2019, 06:45 PM
caulk04
2008 WK
Don't worry about how they look with it jacked up, they're at their limit there. Keep the clevis, front mount of the lca and uca frame side mounts loose until it's on the ground. That'll keep from keeping the bushings twisted at rest.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #4 of 11 Old 05-25-2019, 07:08 PM
underscore
2007 WK
First off, I hate you for how clean everything looks.
For the balljoints, I wouldn't worry too much until everything is back on the ground and you've put a few miles on it for things to settle. Brand new parts will settle quite a bit.
07 WK CRD//QDII//OME MD//OMG WTF BBQ [daily]
91 Celica GTFour RC [for sale]
underscore is offline
post #5 of 11 Old 05-25-2019, 07:53 PM
SteveROntario
You use a floor jack to push the lower control arm up. That will seat the ball joints. Don't do the final tightening until you have the vehicle sitting on the wheels.
Raffish likes this.
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #6 of 11 Old 06-02-2019, 05:38 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Got the front end all back together and pulled it out of the garage to rinse off the months of dust from all the painting, sanding and various other work.
I left the clevis, front LCA, and upper control arm bolts loose before installing wheels and lowering it. Crawled under and tightened everything up for now. The rear ome springs aren’t installed yet. Have new upper/ lower control arms, sway links, sway bushings and track rod, along with coil isolators, a gallon of por15, and a fuel pump on the way to do the rear. Shocks are already new 4600s.
It still looks really high in the front. How much settling can I expect once I get the rest done and have it aligned?
Also as for the rear, any particular order everything needs to come apart/ go back together in?
1170B4B4-B7F8-4571-B739-3135E0ACC08E_1559518651528.jpg   A1AC59D0-E220-4B50-8624-7263B33F8C79_1559518669795.jpg   D440DCCC-E771-4D6F-9308-C2125015D06C_1559518684654.jpg
post #7 of 11 Old 06-03-2019, 01:42 PM
Raffish
2005 WK
Don't most people run the 5100s in the rear and 4600s in the front when mixing OME and Bilstein?
05 WK Limited 5.7, QDII, OME HD, 265/70/17 1.25" Spydertrax, CC, 250xxxkms
Raffish is offline
post #8 of 11 Old 06-03-2019, 03:00 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
I was advised that the 4600s would be okay. The 5100s supposedly add more lift. I didn’t really want any lift at all but I figured the original springs were shot after 190k miles. Haven’t pulled the rears yet but the fronts were pretty well rusted as well. Luckily, if I find I need to get the 5100s, it’s a super easy swap.
post #9 of 11 Old 06-03-2019, 03:08 PM Thread Starter
Rtbrjason
Rtbrjason's Avatar
2008 WK
Got it back in the garage and took a couple measurements. I wish I had measured the front before I took it all apart but that was 2 months ago and I had no plans on lifting it at that time. The front is at about 23” from axle to fender. The rear (still on original springs) is at about 20.25” from axle to fender. I guess that is pretty close to a 2” lift in the front assuming the rears have sagged a bit.
Still not loving the way the upper control arms are sitting in the front with jack and jack stands removed.
post #10 of 11 Old 06-03-2019, 04:20 PM
underscore
2007 WK
It should settle more up front, I want to say I landed at 22 and change with the same setup.
post #11 of 11 Old 06-03-2019, 04:23 PM
Kluk Ztopolovky
it looks great and yes Moog builds tough parts
Kluk Ztopolovky is offline
Garbage Suspension Fix - Front Shocks/struts splouie WK Grand Cherokee & XK Commander Forum 19 05-28-2019 05:12 PM
2017 Grand Cherokee Trailhawk Build djflyy Jeep Builds 78 11-21-2018 01:17 PM
Front suspension vcustoms WK2 Grand Cherokee Forum 4 06-20-2018 08:44 AM
Front suspension clunk connorg5849 KJ Liberty Forum 3 03-06-2018 02:28 PM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
