Forget my oil pan rust- service contract issue.. - JeepForum.com
post #1 of 11 Old 12-01-2019, 02:34 PM Thread Starter
Homer1
Homer1's Avatar
Picked up the 08 GC limited today....after TWO WEEKS...for not starting issues and other things....I get in, and it actually takes a couple cranks to start! "Check engine" light is on, won't remote start, and "Service 4WD" message pops up. Unbelievable. Oh, they hosed me for $700 for the "covered" oil pan, which I have and will attach pics and let you ball busters decide if it leaked because of rust..
Meanwhile, since i've only dealt w/ jeep dealers last 20 years...and can't find one worth the drive...are other manufacturing dealers this incompetent??
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
1997 GC Limited Beach Buggy (Deceased....RIP)
Homer1 is offline
post #2 of 11 Old 12-01-2019, 03:02 PM
Avs
2006 WK
What kind of code did you get? Yea they don’t call them stealership for nothing.
Avs is online now
post #3 of 11 Old 12-01-2019, 09:49 PM
brent_m
Did they do any recalls on your rig while it was in? I know the ignition recall seemed to have a swell of folks with the Service 4WD error popping up. It was an easy fix for the error if I recall correctly.
But yeah, overall you're pretty salty. Let's see some pics of this oil pan. I'll show you mine :P
2007 Jeep Grand Cherokee Overland
5.7 Hemi - Airaid CAI - Magnaflow
brent_m is offline
post #4 of 11 Old 12-02-2019, 04:21 PM Thread Starter
Homer1
Homer1's Avatar
pics are...1st 2 outside rust,next two pan interior.. no rust or holes--pristine!, the 5th is where it seems to have delaminated...and looks bent....and the last are tool marks on top where the delaminating occurred...apparently its a two-ply pan...maybe to guard against rust??
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
Homer1 is offline
post #5 of 11 Old 12-02-2019, 04:28 PM Thread Starter
Homer1
Homer1's Avatar
I know, I wrote "forget about my oil pan" and then went right back to it..my apologies....just now that i have it i really feel ripped off....
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
Homer1 is offline
post #6 of 11 Old 12-03-2019, 05:59 AM
Dacaur
Dacaur's Avatar
2006 WK
Sorry dude, that delamination is definitely due to rust. That pan is far from pristine, Its got rust bubbling up under the paint, thats stage 4 cancer right there.... Terminal. If I were looking for a pan at a pick-n-pull, I would definitely NOT take that one home....
06 WK Limited, 4.7, 2"lift 265/70/17 BFG KO2's
Past jeeps: 03WJ, 99WJ, 99XJ, 92YJ, 92XJ, 85XJ.
Dacaur is offline
post #7 of 11 Old 12-03-2019, 08:18 AM
brent_m
We must have different engines, my oil pan isn't painted. Where was it leaking from?
Do you have a skid plate? All the little spots look like they started as tiny rock dings. Does the shallow side of that pan see more road debris?
PS. I don't have a dog in the warranty fight. That's between you and the dealer/OEM.
brent_m is offline
post #8 of 11 Old 12-03-2019, 11:05 AM
2005JGC
2005JGC's Avatar
2005 WK
It is all about the contract. In my head, so long as it was leaking from the sealing surface, I would think it should be covered. If it is leaking from rust holes, I would say that is the environment and not the manufacturer. At the same time, if it is leaking from the sealing surface NOT because of rust, I would say it would be fair to expect you to pay for the new pan while they warranty the labor. I respect not wanting to do the repair on the dealer side and putting that back on, but if its not leaking BECAUSE the rust I do not see how they are denying the whole claim.
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is online now
post #9 of 11 Old 12-03-2019, 11:34 AM Thread Starter
Homer1
Homer1's Avatar
I noted that the INSIDE is pristine, not the outside, which apparently is another layer. IF it leaked at the delaminated area (the mech indicated it leaked from the sealing edge) and was due to rust, and if rust and/or corrosion was listed in my contract (it isn't, tho it is in my 2017 contract...go figure) then I would have no argument.
No skid plate on this one, maybe that's why its double walled??
THere are no rust holes. That's why i said the inside is pristine.
Thanks for the replies, everyone.
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
Homer1 is offline
post #10 of 11 Old 12-05-2019, 05:34 AM
Dacaur
Dacaur's Avatar
2006 WK
All right, final question, was the spot it was leaking from right at the spot where the rust is in pic 4? If yes, then yes, it was leaking because of the rust, because the rust weakened the edge of the pan there, allowing it to warp enough to leak.
If it was leaking from another spot, then I will agree the rust had nothing to do with it.
Dacaur is offline
post #11 of 11 Old 12-05-2019, 04:20 PM Thread Starter
Homer1
Homer1's Avatar
Well, that was their initial claim for the leak...where the rust was, but I pointed out that rust is not in the contract...as i've stated....but is in my newer jeeps contract ...here's my initial post: https://www.jeepforum.com/forum/f67/...-rust-4378205/
By the way, I barely drove the jeep home before it had to go back...for a battery..which was my initial complaint because it wouldn't start...I picked it up again today. It went in on November 18th. Work done: one upper control arm, one cv boot--both covered--oil pan/gasket (not covered...yet) )and battery, not covered. Only 17 days.
2017 GC Trailhawk
2008 GC Limited
2014 Acura RDX
Homer1 is offline
