Engine Smoking Badly during Regen - JeepForum.com
post #1 of 13 Old 09-22-2020, 09:19 AM Thread Starter
08CRDCanada
2008 WK
Getting heavy smoke coming from the engine bay only during regen, I cant Pinpoint where it's coming from. Any advice?
Only mod is MALONE stage 1 tune.
08CRDCanada is offline
post #2 of 13 Old 09-23-2020, 04:05 PM Thread Starter
08CRDCanada
2008 WK
Bumping up, really need help with this!
post #3 of 13 Old 09-23-2020, 07:50 PM
SteveROntario
Does it smell like engine oil or diesel?
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #4 of 13 Old 09-24-2020, 12:48 AM
rokrau
2008 WK
What color is the smoke?
Dark brownish, look for an exhaust leak but you’d hear it. Cooling hoses all intact? I’d check the PCV valve next to the turbo. Also check intercooler plumbing. Front of the engine. Down the right side going into the cooler and the coming out the left.
Any codes?
How’s it driving. Bumpy?
Good luck.
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #5 of 13 Old 09-24-2020, 12:49 AM
rokrau
2008 WK
Oh and the glow plugs. Maybe one came loose. Could also be injectors.
Enough guessing. Send a video if you can.
rokrau is offline
post #6 of 13 Old 09-24-2020, 02:23 AM
NomadJoe
NomadJoe's Avatar
2015 WK
I have also had this issue after the last exhaust recall/update (like the 5th or 6th now) but I didn't notice it was during regen. Happened 3 times and quickly goes away. 3rd time I was able to open the hood while it was still smoking and it looks to be coming from deep down inside in the area between the bottom of the windshield and engine compartment. Smelled and looked like steam. I had been running the AC so my guess was it was steam from condensation building from the compressor dripping on to the exhaust. Maybe they messed with some heat shielding? I have had it back twice to the dealer and they can't reproduce nor have any idea what it is. They claim it wasn't anything they did. Arrow shows where the "smoke" is coming from. (stock photo)
NomadJoe is offline
post #7 of 13 Old 09-25-2020, 07:58 AM Thread Starter
08CRDCanada
2008 WK
It smells like diesel or oil, smoke is white, gray, blue, smells like the regen normally.
post #8 of 13 Old 09-25-2020, 08:05 AM Thread Starter
08CRDCanada
2008 WK
WhereIs the pcv valve?
I'll try to get a video but it never happens to me, only When my gf drives it. I've tried to replicate the problem but it never does. I caught it once and couldn't find out where it came from. I unplugged the elephant hose thing and it stopped, is it clogged? I have the cb engineering one but never installed it.
post #9 of 13 Old 09-30-2020, 08:03 PM Thread Starter
08CRDCanada
2008 WK
Happened again today, Could not pinpoint where smoke was coming from, could hear the injectors loudly as it was during regen, as soon as injectors went back to normal idle, the smoking stopped.
post #10 of 13 Old 09-30-2020, 08:26 PM
SteveROntario
How do you know you are in regen? I have only caught it once in 110,000 km because it was smoking out the exhaust.
post #11 of 13 Old 09-30-2020, 09:15 PM Thread Starter
08CRDCanada
2008 WK
Can hear the injectors louder, and my regen has always smelt really bad since I owned the jeep.
post #12 of 13 Old 10-01-2020, 08:08 AM
ace28
2008 WK
the PVC is the thing your elephant hose is hooked too ...here is the part from Rock auto
https://www.rockauto.com/en/catalog/...on)+valve,5052
my elephant hose comes out down by the front driver fender(basically the pipe goes straight down under the brake master cylinder), so usually on hot days i see a puff of smoke come up to my left.
One time a guy crossing the street said my jeep is on fire !!! LOL
ace28 is offline
post #13 of 13 Old 10-01-2020, 08:22 PM
SteveROntario
You are going to need to remove the plastic engine cover and the two foam cylinder covers to give it a good look. That will require temporarily removing the clean air pipe from the turbo to get the one chunk of foam out.
