Engine Air Intake Resonator - JeepForum.com
post #1 of 4 Old 08-01-2020, 03:05 PM Thread Starter
Billbo1970
2009 WK
OK... So after pulling this resonator off for the umpteenth time, one of the studs disappeared in the process... I'm assuming it dropped into the fuel rail area but I can't see it anywhere on the ground or in the engine compartment. As a side note, my Torx bit did not come out with my socket extension, and DEFINITELY fell into the fuel rail area when I went to pull it out of the stud on the other side!
#1 can this missing stud and bit work its way into anywhere that would cause me a problem down the road?
#2 The part (Jeep OE 53013378AA - Engine Air Intake Resonator Stud) is not available ANYWHERE!! Anyone know where I can get one?
I know it's not vital to be there, the hose clamps should keep it in place, but I'm OCD
2009 WK 3.7L V6 Laredo
Regards,
Bill
Billbo1970 is offline
post #2 of 4 Old 08-01-2020, 11:17 PM
drew54
2006 WK
Get a small telescopic magnet and start fishing
Also, go check out some salvage yards if you can't find it.
drew54 is offline
post #3 of 4 Old 08-02-2020, 11:30 AM Thread Starter
Billbo1970
2009 WK
Also, go check out some salvage yards of you can't find it.
Thanks for the suggestions! I've been fishing with one that supposedly can handle 15lbs and can't find it I guess junkyard is an option but there aren't too many left in these parts!
Regards,
Bill
post #4 of 4 Old 08-02-2020, 02:14 PM
nvrdone1
2007 WK
get hold of a bore a scope & start looking along the intake & fuel rails. missing bolts, studs etc scare the h... out of me.
nvrdone1 is offline
