Emergency Brake - JeepForum.com
 1Likes
  • 1 Post By caulk04
post #1 of 6 Old 08-02-2019, 02:50 AM Thread Starter
2wk
Emergency Brake
Hey Guys.
I've recently replaced both front and rear rotors/pads OEM and recently noticed that whenever I use the E-brake it's never fully released as the drivetrain starts shaking and once I come to a complete stop it goes away and never come back unless I use the E- brake again.
Brakes were replaced at the dealership. Complained a few times and they coudn't duplicate the issue as I'm sure they never engaged the E-brake.
What do you guys think it could be? E-brake cable I'm thinking? WD40 fix?
Thanks
2wk is offline
post #2 of 6 Old 08-02-2019, 04:25 AM
caulk04
2008 WK
Parking brake is a manual drum located inside the rear rotors. SUPER notorious for the friction material separating from the backing, especially if you don't use them regularly.
You could have another issue related to the cable, but you should be able to tell that in the handle (is the handle feel consistent?).
underscore likes this.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 6 Old 08-02-2019, 11:03 AM Thread Starter
2wk
Thanks for your reply. The handle wasn't consistent till the dealership adjusted it and now it feels normal but something isn't right as its not fully released.
Lets say I apply the parking brake while filling up at the gas station then release it and start driving with no issues till i'm 5 minutes into driving is when I'll feel the driveline shuddering and it doesn't go away unless I come to a complete stop.
2wk is offline
post #4 of 6 Old 06-19-2020, 11:27 AM
Jambalam
Jambalam's Avatar
2007 WK
I'm doing my rear brake pads, rotors, shoes and springs and I've have had that same kind of feeling as if one or two of the rear brakes hasn't fully released. By the time I try to fine tune what's happening, it goes away.
Did you ever find a fix?
2007 Grand Cherokee Limited CRD.
2006 Grand Cherokee Larado 3.7 V6.
Denver,CO
Jambalam is offline
post #5 of 6 Old 09-16-2020, 11:41 AM
superheady
2009 XK Commander
Any resolution to this issue? Feeling the pain as well...
Stay Heady My Friends
superheady is offline
post #6 of 6 Old 09-16-2020, 09:27 PM
Mainsail
2005 WK
Originally Posted by 2wk View Post
WD40 fix?
Is there some water in there that needs displacing?
WD40 is not a lubricant.
Poor grammar is something up with which I shall not put.
Mainsail is offline
