Dual Battery - JeepForum.com
 3Likes
post #1 of 48 Old 12-27-2015, 09:25 AM Thread Starter
MrJimBeam
2006 WK
Dual Battery
Hi All
Does anyone have experience with a second battery (AUX battery)?
MrJimbeam
MrJimBeam is offline
post #2 of 48 Old 12-29-2015, 07:31 PM
Tango.
There are a few jeeps that did this.
Life is hard-John Wayne
Tango. is offline
post #3 of 48 Old 02-19-2017, 02:00 PM
omsok
omsok's Avatar
2007 WK
Is this really the only WK Dual battery setup thread? I will add a couple ideas here, please feel free to direct me to another thread. I did check omelet's and did not see a second battery setup, just replacement of Optima Yellow top with Odyssey.
As a bit of additional info I am building an expo rig, and will a house battery to safely run electrics without compromising starter battery. I have the 3.0 CRD.
I am looking at getting a deep cycle Yellow top and probably mounting in the trunk. I have picked p a ProisoCharge Marine grade alternator Power Distribution System (PDS) that is supposed to e pretty high quality. My only concern is whether or not I need to run an AGM, or staged DC to DC battery charger between the alternator (ProisoCharge) and the house battery.
I have heard that newer vehicles (mine is 2007) have alternators connected to the ECU which limits or controls voltage regulator output based on a complex set of information. I don't really want to start contradicting or messing with things set up by Mercedes engineers, even though my PDS has a terminal to attach a smart alternator lead to.
Thing is if I need a DC to DC charger for house battery, I might as well just get a CTEK Dual, is what I am thinking. Any helpful
input appreciated.
omsok is offline
post #4 of 48 Old 02-19-2017, 03:43 PM
CavallinoRed
2006 WK
found quite a bit of info with this search
https://www.google.com/search?q=WK+D...hrome&ie=UTF-8
CavallinoRed is offline
post #5 of 48 Old 02-19-2017, 04:50 PM
Tango.
I would not put it inside the cab.
Tango. is offline
post #6 of 48 Old 02-19-2017, 07:34 PM
omsok
omsok's Avatar
2007 WK
Thanks
Thanks a lot, looks like some good info. Have been reading Sprinter and 300c forums today for info.
omsok is offline
post #7 of 48 Old 02-19-2017, 07:48 PM
omsok
omsok's Avatar
2007 WK
Thanks. How did you wire up your isolator? I confirmed today with a Chrysler CRD mechanic that these vehicles use voltage regulator controlled through the ECU. Looking at the wiring today I see the positive splits to one of the electrical boxes next to the battery, and to the batter itself. Wondering where you wired in your isolator. Any photo appreciated.
I like the battery tray placement there. Will have to look into that. Any problem with voltage drop from the isolator? Are you using an AGM DC to DC charger?
Thanks again, great help.
I put a Blue optima in the 1/4 panel. The isolator in the front has a delay so when the jeep starts it starts on the main battery only.
All the auxiliary stuff is wired to the auxiliary battery.
It's behind this 1/4 panel.
Jegs sells some optima battery mounts for race cars, and I used one of those to mount it to the frame rail.
omsok is offline
post #8 of 48 Old 02-20-2017, 06:09 AM
Tango.
With the complicated voltage issue and the PCM I found a company from AU that was on ebay called piranha offroad which made isolators specifically for this issue. There are a bunch of companies that make them for this voltage issue, or if you are electrical savvy you can make your own. I went with one of those since I found one at a really good price.
Mounted the isolator to the quarter panel rear of the main battery and next to the 2nd fuse box. Since it's a long run to the rear battery I put a 150 amp breaker on each end. Bought a used huge battery cable from our local marine salvage yard and used that to connect them.
It works great. I run all my offroad lights, ARB fridge and a bunch of other stuff off of it. Plus it has the dual battery setup for winching.
Had it for years now without issues.
Tango. is offline
post #9 of 48 Old 02-20-2017, 08:09 AM
badgerwithhands
2007 WK
Tango, I like that setup. I might steal it, except maybe on the passenger side strictly for weight distribution purposes.
badgerwithhands is offline
post #10 of 48 Old 02-20-2017, 01:13 PM
omsok
omsok's Avatar
2007 WK
Powering the Piranha
Tango: So you are powering the Piranha (DBE 140 DBE 180?) direct from the positive terminal of the main battery? In this way the ECU and the alternator just see it as extra load and manage the alternator output accordingly?
Any photos of your isolator wiring setup would be appreciated.
Thanks a lot.
omsok is offline
post #11 of 48 Old 02-20-2017, 06:33 PM
Tango.
Correct, pretty simple.
Tango. is offline
post #12 of 48 Old 02-20-2017, 06:39 PM
Tango.
also .. if you need to jump the main battery you can just jump the isolator. This can be installed with a marine on off switch jumping the isolator terminals.
Tango. is offline
post #13 of 48 Old 02-20-2017, 07:52 PM
Hemicuda61
Tango, does this setup require a higher output alternator? How is the second battery getting charged? Also, if the main battery is low, does this DBE140 have the intelligence to switch to the auxiliary battery to start the Jeep?
Sent from my iPad using Tapatalk
Hemicuda61 is offline
post #14 of 48 Old 02-20-2017, 08:06 PM
Tango.
This setup uses the OEM alternator, no alternator modification.
Tango. is offline
post #15 of 48 Old 02-20-2017, 08:21 PM
Hemicuda61
Tango, when you say "MANUALLY jump the isolator" do you mean the setup comes with a beefy switch to flip to the aux battery, or you mean to take jumper cable literally and jump the isolator?
