DIY CRD Kidney Delete??? - JeepForum.com
post #1 of 14 Old 08-21-2019, 07:43 PM Thread Starter
johnsquared
2008 WK
Thereís a place near me that has posted the ad below a couple of times and Iím tempted to go check his inventory out... Iím thinking I might be able to come up with the the right pieces to do a kidney delete and possibly a down pipe/cat delete. Plan would be to cut and fit everything then take everything to a welding shop to melt it together.
Any thoughts? Good plan or no?
'08 Grand Cherokee
(Oo)[||||||](oO)
Laredo CRD
johnsquared is offline
post #2 of 14 Old 08-21-2019, 08:24 PM
badgerwithhands
2007 WK
Let me know if it works out. That's actually a pretty good idea. Take your kidney with you
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #3 of 14 Old 08-22-2019, 12:03 PM
underscore
2007 WK
The resonator kidney up front? I deleted mine with the hose from a CAT mentioned in a thread here. IIRC it's just a gentle elbow so if you find the right curve in there and chuck a coupler on each end you should be good to go.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #4 of 14 Old 08-22-2019, 01:34 PM
ggrassmid
2008 WK
I had the CAT hose on my for almost 5 years. It's finally being replaced as I started to get a hole in it from rubbing on the serp belt.
ggrassmid is offline
post #5 of 14 Old 08-23-2019, 03:03 AM
terrasmak
2007 WK
I have the CBE version, and just added a new pipe to link it to the intercooler.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #6 of 14 Old 08-23-2019, 08:21 AM
moonvan
2008 WK
Its pretty easy to make one with a 45 degree bent tube and a couple couplers.
2008.5 Grand Cherokee S-Limited CRD
moonvan is offline
post #7 of 14 Old 08-23-2019, 03:27 PM
Ahaze
2008 WK
I built my own kidney delete from mandrel bent exhaust tubing but made sure to put brackets on it to use the bolts that hold the OE piece. That way it can't rub on any belts or pulleys. I also modified the OE aluminum turbo discharge tube to use a silicone coupler and band clamps so I didn't have to duplicate the weird connection to the kidney on my delete pipe.
A cat / DPF delete pipe is doable too, just much more work. I would suggest you have your own welder for that one so you can at least tack it together as you go. Trying to cut all the pieces and then bring them to someone else to assemble sounds like a nightmare.
Ahaze is offline
post #8 of 14 Old 08-23-2019, 05:58 PM
badgerwithhands
2007 WK
The CAT pipe just seems expensive for its use, in my opinion.
post #9 of 14 Old 08-23-2019, 10:40 PM
underscore
2007 WK
The CAT pipe cost me $40, that's a lot better than $215 for the CBE one.
post #10 of 14 Old 08-24-2019, 08:33 AM
KUJeeper82
KUJeeper82's Avatar
2007 WK
My $150 Russian silicone delete hose is still running strong...
https://rover.ebay.com/rover/0/0/0?m...2F143097423182
KUJeeper82 is offline
post #11 of 14 Old 08-24-2019, 09:43 AM
badgerwithhands
2007 WK
Maybe I had the wrong part number. I found about $95 IIRC
post #12 of 14 Old 08-24-2019, 06:26 PM
underscore
2007 WK
My mistake, I was going off what I had in my notes but I forgot that it can be cut in two and I sold the other half to my friend. Full price it would've been $80 USD which is pretty close to what you found.
post #13 of 14 Old 08-30-2019, 12:19 PM Thread Starter
johnsquared
2008 WK
Finally connected with them and went to pick up some pieces. Turns out the have quite an operation going and the $10 mix & match parts are just their off-cuts, not-quite-perfect, and machine set-up/test pieces. Their website is https://khaosmotorsports.com/ They specialize in Charger/Challenger parts and were super cool to talk to. If you need some random pieces Iíd hit them up - they ship anywhere.
Anyway, pic shows what I got... lighter colored one on the right is aluminum for the kidney delete. The rest are stainless for my *maybe* cat delete.
Iíll update when I have a chance to make something, but Iím a high school teacher so life just got kinda busy for me but hopefully I can get our shop teacher to give me a hand with the welding, since we have a full TIG rig in the shop! But yeah, might be a while!
Sent from my iPhone using Tapatalk Pro
'08 Grand Cherokee
(Oo)[||||||](oO)
Laredo CRD
post #14 of 14 Old 09-01-2019, 09:22 PM
ZJPunk98
ZJPunk98's Avatar
2007 WK
very interesting idea. I look forward to seeing your creation.
Erik
98ZJ sold, 02WJ sold, 07 WK CRD
ZJPunk98 is offline
