DIY CRD intercooler upgrade? - JeepForum.com
 2Likes
  • 1 Post By ggrassmid
  • 1 Post By Gray203m
post #1 of 10 Old 05-23-2019, 09:26 AM Thread Starter
Over-land
2007 WK
So on the never ending quest for upgrades I'm debating on going with a bigger intercooler. It looks pretty easy to install a bigger unit from what I see online other than some piping, connectors and fabbing up some brackets.
Here is the intercooler I was looking at going with https://www.cxracing.com/intercooler...rice&order=ASC
Aside from brackes and some plumbing what else do I need to do?
If anyone has done this give me some tips please!
07 CRD QD2 GDE ECO Tune OEM DPF Delete Russian Silicone hose kit JBA Arms OME lift Rubi wheels
Over-land is offline
post #2 of 10 Old 05-23-2019, 12:47 PM
ggrassmid
2008 WK
I had one installed last summer. There are a few pictures and info in my thread linked in my Sig. That one you linked is same size as mine, which is to wide. I had to have the ends cut and cast 90* elbows welded on, when we did that we matched the 2.5 inlet and 2.0 outlet on the intercooler to the stock intake hoses. Bracketing is easy.
ggrassmid is offline
post #3 of 10 Old 05-24-2019, 08:11 AM Thread Starter
Over-land
2007 WK
Dumb question - could you have installed some 90 degree couplers instead of the elbows?
post #4 of 10 Old 05-24-2019, 08:29 AM
ggrassmid
2008 WK
Not a dumb questions. I did not put those pictures in my thread.
I have attached them here. You can see that you'd have to be more than 90* to get back to the stop hoses, or figure out how to manipulate them.
underscore likes this.
post #5 of 10 Old 05-24-2019, 08:49 AM
Gray203m
2008 WK
I upgraded mine over the winter. I used an intercooler from Ebay
Parts:
2"2"x3' aluminum angle stock
2.5" silicone elbow (intake side)
2.5"x3" aluminum tube (intake side)
2.5"2.25" silicone elbow (outlet side)
2.25"24" aluminum tube (outlet side)
4x2.5" t-clamps
4x2.25" t-clamps
I used the factory hose on both 20190203_151341_1558709300467.jpgsides. The intake needs a couple inches cut off to fit nicely. The outlet side needs to be cut right after the elbow where it increases to 2.25" diameter. You'll have to cut the aluminum tubing to the correct length, but 24" will give you lots of room for mistakes.
Sorry about the picture being flipped, not sure why or how to fix it
2008 WK CRD North
GDE Eco Tune, DPF Delete
2" RC lift, 265/65R18 Duratracs
Gray203m is offline
post #6 of 10 Old 05-24-2019, 08:54 AM
rokrau
2008 WK
I updated mine last year with the CB engineering kit which came with a new throttle body adapter too. Pretty straightforward if the cross member is already out for some other reason.
Did anyone here notice any significant performance change?
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #7 of 10 Old 05-24-2019, 09:09 AM
ggrassmid
2008 WK
I did not notice any performance gains. On my dashboss I notice my intake temps are now under +10*F difference from ambient verses +20*F difference on stock; I am also flowing A LOT more air into mine now too. That does equate to more fuel, more power with the denser cooler air; but butt-dyno couldn't tell.
I see above Gray203 used a narrower IC; which CBE went to. He never posted his current size, but the old size from his R&D time is the size I went with.
post #8 of 10 Old 05-24-2019, 10:29 AM Thread Starter
Over-land
2007 WK
Really appreciate the info guys!
Now I'm second guessing on doing this mod...
I'm coming to the conclusion from actual user reports is that upgrading the intercooler may not be a major upgrade in terms of performance. It seems the people that are saying "increased MPG, faster, more power" are the people selling these components and not from actual users?
Is it worth it?
My CRD is tuned/GDE and DPF & Resonator delete so because of those couple of mods will it net a increase in performance???
If I get 2-3mpg increase it's worth it to me. If I can FEEL a difference then yes it's worth it. If I spend $300+ and a day installing it to say "meh I think it made a difference" then it's a waste of time.
Prove me wrong!!!
post #9 of 10 Old 05-24-2019, 10:46 AM
ggrassmid
2008 WK
Is it worth it?
Prove me wrong!!!
That's up to you. My crossmember got smashed in and also smashed the IC; so mine had to be done. $600 for a stock replacement or $300 for this setup, so I saved some money. If you are just DD'ing mostly, unlikely you'll even see the 2-3mpg gain either. Like I said, I only noticed the change in intake temp, which would equate to increase in hp/tq due to increased air/fuel mix. IMO the 2-3 mpg people see is a total of everything that can be done. If I saw 1-2mpg on each thing over everything I should be at almost 30mpg highway. Currently I see an average, 60%hw/40%city, 23mpg. My best on stock everything was 26mpg running 60mph 98% highway.
I think it would be fun to find a 2wd CRD, swap to a 3.07 rear gear from a v6 gasser, lower it with 245/65(70)/17's low resistance tires, and a GDE/Malone tune and try to actually push the 30mpg envelope at real highway speeds.
post #10 of 10 Old 05-24-2019, 01:19 PM
Gray203m
2008 WK
I noticed a little bit of decreased turbo lag, and a little better city mileage. The biggest difference I noticed was that my EGTs stay lower city driving, and they drop much faster after a highway run.
I should add that I have a GDE hot tune, DPF delete, and resonator delete. With those three, adding in the intercooler did give me noticeably better acceleration.
Also as a note, the intercooler I went with didn't require any trimming of the crossmember, and I opted for the shorter height because I have a 4xguard front mount hitch that would block the added height of the CBE intercooler
2008 WK CRD North
Gray203m is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3856 07-28-2019 09:18 AM
WK CRD CB Engineering Intercooler Jambalam WK Grand Cherokee & XK Commander Forum 26 05-03-2019 09:23 AM
Jeep Liberty CRD Transmission cooler upgrade GitItGarage KJ Liberty Forum 0 04-13-2019 09:05 AM
Silicone Russian CRD Intake & Intercooler hose review Over-land WK Grand Cherokee & XK Commander Forum 4 02-20-2019 03:12 PM
2008 CRD intercooler hose sizing Gray203m WK Grand Cherokee & XK Commander Forum 2 12-26-2018 07:26 AM
