Diesel Oil Change Kit - JeepForum.com
post #1 of 22 Old 02-15-2013, 04:09 PM Thread Starter
NotChris
I know there are a hand full of threads talking about 229.51 spec oil for the 3.0 but had anyone head much about using Total Quartz MC3 oil or even a kit: http://www.idparts.com/catalog/produ...ducts_id=3049?
Going to start changing my own oil in a 2007 and I am always looking for a deal.
NotChris is offline
post #2 of 22 Old 02-15-2013, 05:38 PM
suzieque
2008 WK
not a bad buy for the right oil. There were some guys that tried the Mann oil filter and it started leaking after about 1000kms. Do a search in this forum on the topic. Turned out that Mann was shipping a thinner o-ring. Perhaps they've fixed the problem now, but personally, I use the Mopar (Mercedes) fuel/oil filters on my CRD. To expensive of an engine to take a chance. Maybe you could re-use the old o-rings.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 22 Old 02-15-2013, 08:14 PM
BAH101
2008 WK
Are you sure it was the Mann, not the Framm filters? I have used the Mann HU821X for quite some time with no leaks
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #4 of 22 Old 02-16-2013, 10:46 AM
SSF556
SSF556's Avatar
2008 WK
It was Fram....Mann is good to go
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #5 of 22 Old 02-16-2013, 10:58 AM
Tango.
Watch the oil prices at NAPA. They have a sale every year. Oil is Valvoline 5W-40 and is 229.51 spec. The oil filter you can get at advanced auto. Worked out to be about $60 an oil change. The oil was about $4.99 a quart.
Tango. is offline
post #6 of 22 Old 02-16-2013, 11:13 AM
SSF556
SSF556's Avatar
2008 WK
Also remember if you have done the dpf delete...oil options increase.
2008 CRD QT2
SSF556 is offline
post #7 of 22 Old 02-16-2013, 12:12 PM
Drewd
Yep, DPF delete would be nice way to return to biodiesel blends >5% and allow high SAP oils which have higher TBNs and stronger additive packages in my opinion.
Thanks for the oil info, I just bought a kit and saved a small fortune over what I've been paying at Pep Boys.
Haven't had much luck with NAPA on oil.
Drewd is offline
post #8 of 22 Old 02-16-2013, 07:57 PM
suzieque
2008 WK
Originally Posted by scootr29 View Post
Mann is good to go
no, in these threads the problem was Mann and WIX.
https://www.jeepforum.com/forum/f67/c...ilure-1148553/
https://www.jeepforum.com/forum/f67/2...-leak-1086627/
the problems occurred 2 years ago, so perhaps the newer Mann and WIX filters are ok.
suzieque is offline
post #9 of 22 Old 02-17-2013, 09:12 AM
dieseljeep07
dieseljeep07's Avatar
2007 WK
I have used the WIX oil filter since I have started doing my own oil changes(4+ years) never had an issue with leaks, maybe it was 1 bad batch that I happened to miss.
dieseljeep07 is offline
post #10 of 22 Old 02-17-2013, 12:22 PM
SSF556
SSF556's Avatar
2008 WK
I have used Mann forever...no issues.
2008 CRD QT2
SSF556 is offline
post #11 of 22 Old 02-17-2013, 03:02 PM
Tango.
What are the other OILs that can be used with the DPF delete?
229.5 can be used is there any others? or just the wider array of 229.5 oils?
Tango. is offline
post #12 of 22 Old 02-17-2013, 03:44 PM
SSF556
SSF556's Avatar
2008 WK
According to Mercedes...the OM642 w/o a DPF can use the following oils:
http://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
Mercedes Specs:
228.3
228.5
228.51
229.3
229.31
229.5
229.51
229.52
Generally the "1" indicates a low ash oil for vehicles equipped with a DPF.
I am going to go with the 0W40 Mobil 1 initially and see what happens....
229.5 oils:
Mobil 1 0W40 Synthetic (You can get this at WalMart)
http://matrixsyntheticoils.com/store..._supersyn.html
MOBIL 1 0W-40 CAN BE USED AS BOTH a RACING OR STREET OIL.
Mobil 1 0W-40 synthetic motor oil is an all-purpose, all-weather motor oil with a great reputation. There are many used oil analyses (UOAs) that have been posted and discussed on the “Bob is the Oil Guy” internet forum. This oil has posted many excellent high mileage UOAs. For those people who own vehicles that require a 40 weight oil, Mobil 1 0w-40 should be placed at the top of their list. This Highly versatile and Fully Synthetic oil is Highly Recommended."
Data Sheet
http://www.mobil.com/USA-English/Lub...l_1_0W-40.aspx
Amsoil 5W40 Euro Car Synthetic meets 229.3 and 229.5
http://www.amsoil.com/shop/by-produc...motor-oil-efm/
Common truck oils that make the cut just barely....
Shell Rotella Full Synthetic (228.31)
Mobil Delvac Full Synthetic 5W40 (228.31)
2008 CRD QT2
SSF556 is offline
post #13 of 22 Old 02-08-2018, 02:32 PM
wakacha
2007 WK
Did you ever order from there? Great prices for the kits, looking at the Oil Change Kit (WK)
- Oil Liqui Moly TopTec 4200 (+$10.00) its only $90 and $10 shipping to Canada even!... almost seems too good to be true, have you tried? Or has anyone?
wakacha is offline
post #14 of 22 Old 02-09-2018, 09:48 AM
suzieque
2008 WK
i have not, however, crappy tire has their euro 229.51 oil on sale this week, $30/jug CAD. I'm going to pick up a jug.
suzieque is offline
post #15 of 22 Old 02-09-2018, 10:06 AM
KUJeeper82
KUJeeper82's Avatar
2007 WK
Man do yourself a favor when changing your oil and install a Fumoto quick change valve.
Fumoto F-105N Engine Oil Drain Valve https://www.amazon.com/dp/B003VCEV0Y..._dtDFAb6DHY15G
KUJeeper82 is offline
