Did a front brake job and used a great tool.... - JeepForum.com
 5Likes
  • 3 Post By LouC
  • 1 Post By LouC
  • 1 Post By Mr. Puddles
post #1 of 11 Old 08-12-2019, 05:39 PM Thread Starter
LouC
2007 WK
If you ever dread having to replace rotors on an older vehicle, because you know they are going to be stuck on...yes there are some tricks such as using the bolt and 2 nut tricks but I found a great tool made by OTC tools, that is a drum puller but it works well on rotors too...I sprayed penetrating oil in the lug holes and around the center bore, hooked up this tool, and with a couple of turns the rotor popped free! Even using the bolt trick on the rear which I did took me a while, this was like 2 min and its off. On the WK the rotors were original they were on all of 13 years and 110,000 miles. So I give this tool 5 stars!
https://www.otctools.com/products/he...d-rotor-puller
of course I gave the hub and inner face of the rotor hat a coat of anti seize in case I ever have to take em off again.
Walt, underscore and JeepN_A_CJ7 like this.
2017 JK Unlimited Sport 6 spd
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #2 of 11 Old 08-12-2019, 06:07 PM
DougRz
Looks good.
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_) 03 auto, Ford 8.8, 4.88, Tru-tracs
DougRz is offline
post #3 of 11 Old 08-13-2019, 12:38 AM
ravenworks
ravenworks's Avatar
When I had problems,I just used a blunt ended air chisel
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 11 Old 08-13-2019, 12:11 PM Thread Starter
LouC
2007 WK
Glad that's done!
99sajeep likes this.
LouC is offline
post #5 of 11 Old 08-13-2019, 01:46 PM
Mr. Puddles
Ive always gone for the BFH
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #6 of 11 Old 08-13-2019, 08:49 PM
2005JGC
2005JGC's Avatar
2005 WK
My go to tool for this is living in the Pacific NW Screw road salt!!!!
2005 Jeep Grand Cherokee - Work in progress...
2005JGC is offline
post #7 of 11 Old 08-14-2019, 10:00 AM Thread Starter
LouC
2007 WK
I think no matter where you live if there is moisture in the air, cast iron/steel will rust. When you got a stuck rotor there are a few options...one is the brute force sledgehammer method but that is risky since it puts a lot of force on the bearings inside the hub. The other method that works is the bolt through the hole on the steering knuckle trick with 2 nuts on it, that can be used to push the rotor off (use one bolt with 2 nuts on it in each mount hole, put the old pad against the rotor to spread the force out. That is how I got the back ones off back in December, the rear mount is threaded so I just got longer bolts of the same thread, put a bolt on the end and then put the old pad against the rotor to spread out the force. The 2 bolt trick works without banging on it with a sledge but it takes longer as you have to rotate the rotor to apply the force in different spots on the rotor.
Here's how I removed the rear ones. No banging with big sledge, back off the star wheel for the parking brake all the way...get longer bolts with a nut...etc...just get it nice and tight, take a hammer and just tap, no banging needed after letting the penetrating oil soak in...
LouC is offline
post #8 of 11 Old 08-14-2019, 10:03 AM Thread Starter
LouC
2007 WK
And before installing the rotor....coat both the hub....and the inner mating surface of the rotor with anti seize...and next time the rotors will literally slide off...
On our '98 ZJ I have been doing brake jobs on it since it was about 2 years old, I am up to about 4 brake jobs front and rear I think....and since I always used anti seize..the rotors have never been stuck on...
LouC is offline
post #9 of 11 Old 08-14-2019, 10:24 AM
zjeb67
2014 JK Wrangler
Excellent tip on preventing trouble the next time around
zjeb67 is offline
post #10 of 11 Old 08-14-2019, 03:24 PM
ggrassmid
2008 WK
I just bang mine off with a large dead blow hammer and hearing protection. Worst case is you use a metal sledge and bend the rotor you are replacing anyways.
ggrassmid is offline
post #11 of 11 Old 08-14-2019, 05:09 PM Thread Starter
LouC
2007 WK
But what about the wheel bearings? I wonder how many people have had wheel bearing failure not long after banging off the rotors? BTW, since I had to do brake jobs on the '98 ZJ early on (the oe rotors on those never lasted, aftermarket was actually better) I always coated the hubs with anti seize. Never had to use a hammer once. And, the bearings on that Jeep have never had to be replaced...even at nearly 180,000 miles....just wondering about that.....
LouC is offline
