Custom Tire Carrier and Winch Mount - JeepForum.com
 8Likes
  • 1 Post By Neuance
  • 2 Post By Neuance
  • 1 Post By Neuance
  • 1 Post By Neuance
  • 3 Post By Neuance
post #1 of 12 Old 03-31-2020, 07:22 PM Thread Starter
Neuance
Been having fun building items for my 2008 WK CRD. Has a 2" lift, 255/75/17 tires with 1 1/2 wheel spacers, GDE tune and delete. Fabricated a tire carrier a couple months ago, just finished building the winch mount (still needs blast and paint). Next aux fuel tank where spare went.
20200331_182437_1585703709402.jpg   20200331_170717_1585703750486.jpg   20200331_160554_1585703974598.jpg
JeepN_A_CJ7 likes this.
Neuance is offline
post #2 of 12 Old 04-01-2020, 08:51 AM
cigrum
2007 WK
looks good, is the winch mount bolted down by using the existing tow hook setup?
Do you have a pic of your tire carrier, I'm interested in the design you chose.
cigrum is offline
post #3 of 12 Old 04-01-2020, 09:38 AM Thread Starter
Neuance
I cut out all but the back plate of the front crossmember so I could recess the mound an extra 4". Used a 2x2x1/4" that runs under the frame rails aprox 16" and uses 3 bolts with a backing plate through existing holes in the frame (front two holes were for the toe hooks), and one bolt through the side of the frame. Also attached pics of the tire carrier.
20200401_093011_1585755359741.jpg   20200401_092926_1585755389845.jpg   20200401_092957_1585755419031.jpg   20200401_092839_1585755445737.jpg   20200401_092853_1585755465840.jpg
Neuance is offline
post #4 of 12 Old 04-01-2020, 10:06 AM
SteveROntario
How big of a fuel tank are you going to build? I am going to look at some stainless steel rectangular ductwork tonight to see if I can make something with it. The people who did the process equipment for a plant in Kingston are offloading a bunch of stuff locally.
https://www.kijiji.ca/o-profile/1019385995/listings/1
2013 Civic, 2009 Suzuki DRZ-400SM, 2008.5 Grand Cherokee CRD, 1991 Dodge B250, 1934 Hupmobile 417W
SteveROntario is offline
post #5 of 12 Old 04-01-2020, 06:54 PM Thread Starter
Neuance
Not sure what the volume is but it takes up most of the spare tire well. Does not protrude below the frame rails.
Neuance is offline
post #6 of 12 Old 04-01-2020, 09:03 PM
SteveROntario
Please post photos and overall dimensions. I went to the steel place and it's ridiculous. All the stainless steel you can dream of in every diameter fully polished.
post #7 of 12 Old 04-07-2020, 02:44 AM
Witblitz
looking good any progress on the fuel tank setup where the spare wheel is?
Witblitz is offline
post #8 of 12 Old 04-07-2020, 10:42 AM Thread Starter
Neuance
Going to pick up the steel tomorrow. They just got all the parts cut out for me. So tomorrow I will start welding it together. Also changed out the steel main tank for the plastics gas one, easy job. Definitely needed to be done, it had lots of pin holes in it, I think the only think stopping it from pouring out was the yrs of dirt cakes on it lol.
Neuance is offline
post #9 of 12 Old 04-08-2020, 11:15 AM Thread Starter
Neuance
Making progress
SteveROntario likes this.
Neuance is offline
post #10 of 12 Old 04-08-2020, 05:39 PM Thread Starter
Neuance
Winch and mount installed
Neuance is offline
post #11 of 12 Old 04-08-2020, 08:38 PM Thread Starter
Neuance
Here's how the tank fits up under rear. Just mocked up at this point.
Witblitz likes this.
Neuance is offline
post #12 of 12 Old 08-14-2020, 05:12 PM Thread Starter
Neuance
Finally installed and filler figured out.
Neuance is offline
