CRD Oil Temp Sensor - JeepForum.com
post #1 of 12 Old 11-12-2008, 10:32 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
CRD Oil Temp Sensor
While perusing the Service Manual for my 07 GC CRD, I found a listing and picture for a oil temp sensor.
Has anyone been able to tap in to this to get a reading on an oil temp gauge?
The pic shows it located at the rear of the oil pan.
I bought the DashHawk mainly to read oil press/temp, but those are about the only two readings it doesn't receive.
I'll be going under to change the diff fluids tomorrow and will check out if the sensor is indeed there.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | Million Miles Club | Dogpiled Club | pre-N23 FDCM | Missing Merlin |
89 GW w/plow | Rusting away | Running strong | Plowing like crazy |
wookiee is offline
post #2 of 12 Old 11-12-2008, 01:39 PM
boxcab
boxcab's Avatar
2007 WK
There is a sensor in the pan next to the drain plug. Interesting. I hadn't thought what it was for, but its location could really only be for oil temp.
Doug
2007 WK CRD
boxcab is offline
post #3 of 12 Old 11-12-2008, 02:12 PM
TonyVideo
TonyVideo's Avatar
2008 WK
I would be interested to see if you can get this to work. I am interested in purchasing a Dashhawk or ScanGauge.
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
post #4 of 12 Old 05-17-2011, 08:21 PM
Drewd
Where did you purchase the factory service manual? I need one badly. Thanks!
Drewd is offline
post #5 of 12 Old 05-17-2011, 09:20 PM
TurboDiesel
TurboDiesel's Avatar
2008 WK
im pretty sure u can download a service manual off ebay
and it gets sent to your email in PDF format
TurboDiesel is offline
post #6 of 12 Old 05-18-2011, 08:12 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I got my 4 Volume Real-book version from adlerbrau off eBay for $179.
https://www.techauthority.com/en-US/...x?itemID=10010 sells them for $375.
wookiee is offline
post #7 of 12 Old 05-18-2011, 08:27 AM
Tuco
Tuco's Avatar
2007 WK
Does that 4 volume set have a lot of CRD information? I too have been looking for a factory service manual that has all the CRD info and until this day have not found one.
07 WK CRD Limited
Tuco is offline
post #8 of 12 Old 05-18-2011, 11:32 AM
suzieque
2008 WK
I wonder if you may end up going to a Mercedes equipped 3.0L service manual.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #9 of 12 Old 05-18-2011, 12:46 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Not much info on the crd.
All crd sensors are shown in the electrical section, but not much on the engine itself.
wookiee is offline
post #10 of 12 Old 05-18-2011, 01:45 PM
suzieque
2008 WK
the sprinter guys are recommending this service manual cd
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
I will order one and compare to alldatadiy which is pretty basic.
suzieque is offline
post #11 of 12 Old 05-19-2011, 09:04 AM
nostaw22
FYI - They don't make the DashHawk any more... I had the LCD on my DashHawk break.... When I got it replaced under warranty I needed to upgrade the firmware and when I was asking about that they told me they'd come out with something newer.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #12 of 12 Old 05-13-2021, 05:34 PM
Allllchemist
2008 WK
Old thread...but my 2008 WK is going strong at 240k miles. got the CEL this week, opened Torque on my android and i see p0195 and p0198 codes. checking coolant and tranny temps I knew this was probably a bad reading. this is the only thread that correctly IDs the location of the oil temp sensor. Every source online, including MOPAR, shows the oil temp sensor on the front of the engine near the oil pressure sensor. This is wrong. trial and error, pulling sensor plugs and clearing CEL/codes and rereading show these two sensors up front to be fuel pressure and fuel temp sensors (larger vs smaller sensors, respectively). When I crawled under and touched the sensor on the oil pan, the plug basically fell away from the sensor - it had snagged on some brush or something. replugged, cleared codes and they stayed clear, CEL gone. Thanks for the (old) original post.
Allllchemist is offline
outside air temp sensor limited_pit ZJ Grand Cherokee Forum 7 09-22-2009 11:35 AM
Need Help With Temp Sensor MIKEGW ZJ Grand Cherokee Forum 3 07-14-2009 03:18 PM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 09:04 AM
Where is outside air temp sensor? dickensheets ZJ Grand Cherokee Forum 12 01-28-2007 07:03 PM
Temp sensor wheelytyred ZJ Grand Cherokee Forum 3 02-21-2005 09:13 PM
