CRD modified intake for oil leak - Page 2 - JeepForum.com
post #16 of 248 Old 09-24-2009, 10:39 AM Thread Starter
merlinTec
merlinTec's Avatar
Originally Posted by suzieque View Post
a tight seal is always good, but I wouldn't pay for it. if I see a TSB with the parts and instructions, I will take it to my dealer and have them install under warranty.
Why wait for the T.S.B ? If you have an oil leek print this and take it to your dealer. You don't need a T.S.B just an oil leak but yes I believe a T.S.B is on the way but not a recal.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #17 of 248 Old 09-24-2009, 10:54 AM
suzieque
2008 WK
Regards,
Merlin
good point, but in my case I have a Racor, so I'm in no rush. If I didn't have the Racor, I'd be calling the dealer to get the part and schedule the install.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #18 of 248 Old 09-24-2009, 02:51 PM
johnniebravo
2008 WK
very interested in this as I have a follow up appointment next week.
can anyone tell me what part this: 53013672AD ?
It's only one off from the new hose part number I believe.
2008 CRD GC
johnniebravo is offline
post #19 of 248 Old 09-24-2009, 03:59 PM Thread Starter
merlinTec
merlinTec's Avatar
Same pipe just the old type with the orange seal not the modified one. The AD pipe will still leek.
post #20 of 248 Old 09-25-2009, 06:26 PM
SSF556
SSF556's Avatar
2008 WK
Called my local Jeep dealer and this part is not available anywhere in the US. He told me to call back in a couple of weeks.
SSF556 is offline
post #21 of 248 Old 09-26-2009, 02:09 AM Thread Starter
merlinTec
merlinTec's Avatar
Did they order you one anyway? We have supply issues in the UK too but I V.O.R my one for my customer to get this pipe for him (and for this forum) taken a month to get it but if I had told my customer to just keep calling back in two weeks I think it would still be back order.
post #22 of 248 Old 09-26-2009, 07:27 AM
SSF556
SSF556's Avatar
2008 WK
When I call back in 2 weeks I will probably have him order it at that time.
SSF556 is offline
post #23 of 248 Old 10-07-2009, 06:10 PM
johnniebravo
2008 WK
well I took mine in for the oil leak and they just replaced it with an original pipe, Part number 53013672AD.
There is more...the work order shows that they also did the following:
problem-oil leak at intake pipe to turbo
"cause: blocked/oil softened
09201601 Seperator valve
5175514AB Valve
68051342AA Hose-Cylinder Head to INT"
"Inlet Tube 14103539
53013672AD Hose-Air Cleaner to turbo"
so it looks like i will be going back in a few weeks for another oil leak.
I check with the parts department and they did have the new tube "AE" in the system but it was a special special order and would take about a week to get in. He said 107 were on the way to the northern virginia area and 60 more were on back order. The cost of the part if I wanted to buy it outright was $105.
2008 CRD GC
post #24 of 248 Old 10-07-2009, 08:37 PM
ctate
2007 WK
105 for the tube! man thats crazy
07 Silver 3.0 CRD, Clifford matrix 50.5x remort start/turbo timer, 265/70R17 Goodyear DURATRACS, XD Series Spy wheels, OME Lift Kit, Kenwood navigation system with reverse camera, Inmotion tuned, Amsoil air filter, Fitch fuel catalyst, Air Lift suspension air bags with air compressor, P3 brake controller, MBRP Exhaust, Accu Pro Calibrator, Addco front/rear anti sway bar, Husky Liner floor mats, upgraded air intake tube, Quick Oil Drain Valve.
ctate is offline
post #25 of 248 Old 10-08-2009, 08:13 AM
Jscheier
2007 WK
Centennial Jeep (Arapahoe & I-25 in Denver) ordered one for me when I was in last week to get a leaking transmission sensor replaced. I showed them where the oil was leaking and they ordered the part (AE part). Said it would probably take 2-3 weeks to come in.
Edit - It is here! They won't hand it to me though... so the CRD goes in Monday for them to install (lunacy!).
2007 Jeep GC QD2 CRD (GDE equipped Toy Hauler)
2012 Boss 302 (Track Toy)
Jscheier is offline
post #26 of 248 Old 10-10-2009, 05:48 PM
no-blue-screen
2008 WK
I wouldn't mind putting out the money....if I knew for sure it stops the leaking.
SOLD 2008 WK CRD Limited 4x4 - Jeep Green
no-blue-screen is offline
post #27 of 248 Old 10-11-2009, 02:17 AM
justa4banger
2007 WK
if you have a provent of racor, you shouldn't have any leaks..atleast i don't the intake is free of oil, thanks racor.
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline
post #28 of 248 Old 10-11-2009, 03:32 AM Thread Starter
merlinTec
merlinTec's Avatar
it's should be covered by warranty so why pay?
post #29 of 248 Old 10-12-2009, 09:27 AM
chadhargis
2008 WK
I put a Racor on, and my tube is dry. Even my Racor doesn't collect much oil. Not nearly as much as my Liberty CRD did.
Chad Hargis
Nashville, TN
2008 Grand Cherokee CRD
chadhargis is offline
post #30 of 248 Old 10-12-2009, 09:43 AM
Jscheier
2007 WK
Mine is being installed today. Will give an update on 'leaks' in about 7 days.
Jscheier is offline
intake manifold is crack or leak ? NeverL8 ZJ Grand Cherokee Forum 0 01-24-2010 03:44 AM
Modified RK and RRO lift??? crazypastee WK Grand Cherokee & XK Commander Forum 1 11-07-2009 08:19 PM
Oil Leak At Turbo Intake fred99x WK Grand Cherokee & XK Commander Forum 15 09-18-2009 11:49 AM
CRD Intake Leak - Merlin? 2007GrandDiesel WK Grand Cherokee & XK Commander Forum 3 03-02-2009 04:16 PM
Intake leak? cocot ZJ Grand Cherokee Forum 2 02-08-2004 01:09 PM
