CRD experts. What might be leaking here - JeepForum.com
post #1 of 3 Old 10-18-2021, 12:36 AM Thread Starter
rokrau
2008 WK
Would anybody have an idea what could cause thick, black, grimy buildup right under the strange plastic resonator thing as shown in the attachment?
Is this my throttle body leaking?
Or gunk slung up there from some place else?
Also. What is that resonator for?
What sensor sits there?
Thanks
A4E8FF03-8084-4D50-B8A1-8352E5D81BFA_1634535123489.jpg   6BC5ED63-4910-4548-BCB2-B6DD4013706A_1634535363606.jpg
--Roland, 2008 Grand Cherokee Overland, 3.0 CRD, EHM and TRD
rokrau is offline
post #2 of 3 Old 10-19-2021, 04:43 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
If the connection of the turbo pipe just above the resonator isn't made correctly, oil will mist out of there. It also has an o-ring to check.
Whatever the source, you have about 5,000 miles remaining before your belt shreds (due to oil contamination). You might want to change it after you correct the problem.
Look at page 6 of Chirpz pdf bottom pic to see where I mean.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | ¼ Million Miles Club | Dogpiled Club | pre-N23 FDCM | Missing Merlin |
89 GW w/plow | Rusting away | Running strong | Plowing like crazy |
wookiee is offline
post #3 of 3 Old 10-20-2021, 08:29 AM
Benzrokee
2008 WK
One other place to look is at the oil filter housing where it mates to the engine for leakage, this is so close to the belts and pulleys that it can spray and be thrown around the entire front of the engine. The resonator itself is also known to crack, so it could come from there:
Best method for tracking down leaks is to first de-grease and clean the entire front area of the engine, and then monitor for fresh oil.
Benzrokee is offline
