Clicking noise coming from rear on 2005 WK Limited with QDII - JeepForum.com
post #1 of 8 Old 09-25-2016, 04:17 PM Thread Starter
dcaprio
2005 WK
I have a weird clicking noise coming form the rear axle on a 2005 Grand Cherokee Limited, 5.7L, QDII. Sounds like playing cards in spokes of bicycle wheel. I have attached a link to a video I found on YouTube as I cannot record it well. Sound is exactly the same as in this video. Any help would be appreciated.
'05 WK Limited 5.7L HEMI - 2" Rough Country Lift, LT245/75/17 Big-O A/Ts, Saguaro 4x Components 3/4" shackle mounts and antenna mount, Midland 1001Z CB radio, Firestik 3' antenna, Bilstein shocks, Stillen Metal Matrix pads and rotors, 4XGuard 12 Bolt Rear Differential Guard
dcaprio is offline
post #2 of 8 Old 09-25-2016, 05:18 PM
tom19511
2014 WK
Maybe axle bearings, or driveshaft .Are you certain it is the axle? Looks like you have a laundry list of mods on it...
I would have it put up on a lift with it running in gear to pinpoint it...
Tom
tom19511 is offline
post #3 of 8 Old 09-26-2016, 08:59 PM Thread Starter
dcaprio
2005 WK
Thanks for the reply Tom. Rear wheel bearings have been replaced recently. I am not positive it is the axle. And today I took it to a Gear and Axle shop today and had it evaluated. The owner took it for a drive and put it up on a lift. He has never heard the noise before. He thinks the diffs are fine as well as the driveshafts. He is pointing to the transfer case and suggested to try a fluid change first. I did that today and it didn't seem to help. I think the next thing is to take it to a transmission repair shop and see what they think. Any other ideas for now?
Thanks again!
dcaprio is offline
post #4 of 8 Old 10-03-2016, 01:05 AM
DavidGascon
I fixed this on my jeep yesterday. Upon 2 weeks of research, I leaned the glue that holds the parking brake pad in place sucks. The pads tend to fall off the drum, and cause a clicking noise. All I did was remove the rotor on my rear brake, and my pads just fell off. No more noise, but no parking brake for now. Hope it helps!
DavidGascon is offline
post #5 of 8 Old 10-03-2016, 01:06 AM
DavidGascon
Originally Posted by dcaprio
Thanks for the reply Tom. Rear wheel bearings have been replaced recently. I am not positive it is the axle. And today I took it to a Gear and Axle shop today and had it evaluated. The owner took it for a drive and put it up on a lift. He has never heard the noise before. He thinks the diffs are fine as well as the driveshafts. He is pointing to the transfer case and suggested to try a fluid change first. I did that today and it didn't seem to help. I think the next thing is to take it to a transmission repair shop and see what they think. Any other ideas for now? Thanks again!
see above
post #6 of 8 Old 10-03-2016, 05:27 AM
TJsWK
Probably the locking nut for the pad fir the brake right.
TJsWK is offline
post #7 of 8 Old 10-03-2016, 07:24 PM Thread Starter
dcaprio
2005 WK
Thanks for the advice. I pulled the rotors as suggested and the parking brake pads fell out on both sides. I thought this would fix the issues. Lo and behold, it did not. Since I have also replaced the rear diff fluid, still making noise. I think I my need to visit a tranny shop and see what they say.
dcaprio is offline
post #8 of 8 Old 10-03-2016, 08:22 PM
BAH101
2008 WK
Rear drive shaft. Mine did the same, replaced shaft with replaceable joints and it's gone. I couldn't even articulate the rear joint by hand.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
