A/C Blowing Hot on Passenger Side! - JeepForum.com
post #1 of 13 Old 07-11-2019, 06:06 PM Thread Starter
jmcnell
jmcnell's Avatar
I have had this problem before on a 2007 Cherokee. Replaced the Blow Motor Resistor and it fixed it. Well I did this and nothing. Also anyone know what refrigerant 2006 Jeep Grand Cherokee Laredo 4x4 takes. It is due for a recharge for sure. It has been reach 117F out here in PHX and only thing blowing somewhat cold is my driver side A/C. The heat is really messing with this Jeep!!!
jmcnell is offline
post #2 of 13 Old 07-13-2019, 05:17 PM
dented
Anything new will have R134a
dented is offline
post #3 of 13 Old 07-15-2019, 12:33 PM Thread Starter
jmcnell
jmcnell's Avatar
Ok this is not a Freon issue as I checked and I am almost full. Yes R134a. The system is duel A/C. It seems to be a problem with a divider or the blower motor resistor. I replaced the HVAC Heater Blend Door Actuator and Blower Motor Resistor. I did this when I first purchased the vehicle. Since it just blasts the driver side with cold air I wasn't too worried about it but now it seems to be getting worse as the passenger side is quite hot. We are hitting 115 daily so this is quite urgent anywhere I go I get out of the car pretty sweaty.
This is what my control panel looks like.
jmcnell is offline
post #4 of 13 Old 07-15-2019, 12:55 PM
dented
Do these doors work via vacuum? On Cherokee XJs when there is a vacuum leak everything blows out of the defroster and it can't be changed. Replace a small vacuum hose is all it takes.
I'll look more into your system.
dented is offline
post #5 of 13 Old 07-15-2019, 02:13 PM Thread Starter
jmcnell
jmcnell's Avatar
I am not sure. This all seems to be mechanical gear issues/resistors etc. I took off the blower motor resistor and found to my horror these have completely melted off.
Here is what I found I have no idea what the blower motor connects too! I don't think I'll be running the A/C at all given this problem.
Here is what it should look like.
Then completely unrelated this wire was just hanging about haha
What does the blower motor connect to where those spindles were completely burnt/broke off??!?
jmcnell is offline
post #6 of 13 Old 07-15-2019, 08:07 PM
dented
Do you have the Factory Service Manual? You should be find how everything goes together what attaches to what.
dented is offline
post #7 of 13 Old 07-16-2019, 08:20 AM
Saudade
1988 XJ Cherokee
Not to be "that guy" but you're in the XJ forum. You might get better assistance in the correct forum.
Good Luck!
Saudade is offline
post #8 of 13 Old 07-16-2019, 02:21 PM Thread Starter
jmcnell
jmcnell's Avatar
Good Luck!
Well to be that guy I am in the right forum this is a 06 Jeep Grand Cherokee!
jmcnell is offline
post #9 of 13 Old 07-16-2019, 05:57 PM
BaileyNB
1947 CJ2A
The 2006 Grand Cherokee is a WK...
BaileyNB is offline
post #10 of 13 Old 07-17-2019, 07:38 AM Thread Starter
jmcnell
jmcnell's Avatar
Well now I know! haha
jmcnell is offline
post #11 of 13 Old 07-17-2019, 10:31 AM
BadExample
BadExample's Avatar
2006 WK
Suggest you search around on the WK forum for "blender door." Comes up all the time. I haven't had to work on my cooling so far, so sorry, but I can't help other than to suggest searching. You might even just look through the titles on the first page or two of this forum. It comes up about weekly. You could also use google to search just this forum if you have no luck with the built in search. Copy and past this into google:
"blender door" site:jeepforum.com/forum/f67/
That should focus your search on just the WK forum.
CJ5 we don't talk about, 58 Willys CJ-3B gone
79 J-10 gone, 99 GC WJ murdered and gone
2006 GC WK
BadExample is offline
post #12 of 13 Old 07-17-2019, 10:04 PM Thread Starter
jmcnell
jmcnell's Avatar
So it looks like to get to the axle that has broken off I either dremel a hole or I remove the entire dash from all of my research on this. I would rather dremel my way in then remove the entire dash
jmcnell is offline
post #13 of 13 Old 07-18-2019, 10:58 AM
Alex_
I had the same thing happened on a 2009 but it was the opposite passenger side cool and driver side is hot; it turned out to be the evaporator you could probably get that checked; Dont know if the a way to diagnose it without taking the whole dashboard apart.
Alex_ is offline
a/c , blower motor resistor , cherokee , hot
