Buying items for a Jeep WK build. - JeepForum.com
post #1 of 9 Old 02-06-2015, 09:12 PM Thread Starter
instance
2005 WK
So I am off to college, and have had my 2005 jeep grand cherokee limited for over a year now. 5.7L Hemi, and it is black. I plan on buffing it up. I will be getting a suspension lift which i havent decided on what to go with, XD series rims, and some 265/70 duractracs. Other accessories include wheel spacers, tinted head/tail lights, darker windows, and maybe some audio work.
Does anyone have any ideas on what suspension lift i should go with? Would a budget booster be worth it? And how much do you guys think this would cost?
Thanks!
instance is offline
post #2 of 9 Old 02-10-2015, 08:35 AM
1222
RIP John
1222's Avatar
Moved from the Jeep Buying forum.
(2011-2016)
1222 is offline
post #3 of 9 Old 02-10-2015, 09:55 AM
skibum555
2005 WK
The budget boost is sufficient for looks and lite off road use. If you are really looking for performance more than looks then go with the Old Man Emu lift. It is a spring lift not spacers so the ride is better. also if you haven't already, factor in the cost to replace struts and shocks, if you are tearing it apart you might as well put in new shocks and struts. If they are original they are worn out. use the money to buy a better lift rather than tint and audio work. The budget boost is fine if you are set on it but it doesn't compare to the OME lift. it will set you back around 700. contact Kolak on this forum and he will make you a deal. or crawloffroad.com I think is the other guy who sells OME lifts at a good price.
Jeepin ain't easy...
Proud Member of the BlAcK wK club
MEMBER #105
skibum555 is offline
post #4 of 9 Old 02-10-2015, 01:51 PM
luckyse7ens
2010 XK Commander
OME HD lift would be the most recommended cost effective lift. You can buy it springs only, or with shocks and struts. This will offer you ~3" lift and an improved ride.
Your shocks and struts should be replaced with most lifts, and are completely worn out @ this point most likely anyways.
Wheel spacers are completely unnecessary if you are replacing your wheels. Get your wheels with the right backspacing.
Black WK Club #152
luckyse7ens is offline
post #5 of 9 Old 02-14-2015, 08:43 PM Thread Starter
instance
2005 WK
Thanks for the advice. I guess the springs/struts would be worn out if their factory on a 2005. Even if wheel spacers are not necessary, I still would like to include them. I am more for looks than performance off-roading. Is the OME a significant difference riding in town? Also, i might change my mind about XD series wheels because I saw some WK's with wrangler JK moabs. Havent decided yet, anyone know names of some other nice 17" black wheels?
instance is offline
post #6 of 9 Old 02-14-2015, 09:45 PM
BigAl18
Fuel offroad rims are nice.
BigAl18 is offline
post #7 of 9 Old 02-15-2015, 06:26 PM Thread Starter
instance
2005 WK
Users with the OME lift - Does the OME have a significant difference driving on pavement?
instance is offline
post #8 of 9 Old 02-16-2015, 04:27 PM
luckyse7ens
2010 XK Commander
My understanding is yes.
It is definitely a higher spring rate
Black WK Club #152
post #9 of 9 Old 02-16-2015, 08:49 PM
SRB79Ultras
SRB79Ultras's Avatar
2005 WK
I know that you like the look of spacers but I'll definitely second what someone said above - if you are already getting different wheels, just make sure you get the ones with proper back spacing and you will have the same visual effect the spacers would give you, without the liability that the spacers are. I mean - I currently run them on stock ronninII rims, but Im just saying that it would be crazy to go with them if you are already getting different wheels. Also, check out my build thread for another lift alternative.
Good luck!
www.jeepforum.com/forum/f22/srb79ultras-05-wk-4-7l-build-thread-2802146/
SRB79Ultras is offline
advice , build , jeep , lift , wk
