Brakes are meh - JeepForum.com
post #1 of 7 Old 10-22-2019, 11:12 PM Thread Starter
JDePietro
JDePietro's Avatar
2005 WK
Brakes are meh
Howdy all! It’s been a long time since posting. My profile isn’t up to date (I know I’ll get on it). I recently bought an 05 WK Limited with a 4.7. All the bells and whistles even Quadradrive II (super cool). Anyway my question is about the brakes. When I got it the pedal almost mashed to the floor. So I bought new rotors and pads all the way around since they looked original. While doing the fronts a few of the pots were cracked to bits and fell out into pieces. Two brand spanking new calipers later I had new brakes all around even bled out all the old fluid. The brakes work, fine I guess it just takes more pressure than what I’m used to, to slow down and stop. The pedal doesn’t go to the floor but it’s just lack luster. Is this pretty common for these vehicles? Would changing out the master cylinder make any difference? Thoughts?
Man's got to know his limits.
JDePietro is offline
post #2 of 7 Old 10-23-2019, 12:51 AM
Windexer
Doesnt sound right to me, but braking is a area that is relative to what you are used to, I've got a few different cars I drive regularly and the WK's brakes are somewhere middle of the pack, they were certainly a upgrade from my XJ's and are onpar with my Ford sedan that weights 1,000 lbs less. Maybe readup on how to test out the master cylinder for its performance.
(I've got the 5.7 but I think they all have the same braking setup)
2005 WK Limited Hemi, 2" OME lift, header back exhaust, 245/75/R17 MT, Superchips tuned, Roof rack
Windexer is offline
post #3 of 7 Old 10-23-2019, 01:55 AM
gspfunk
gspfunk's Avatar
2019 WK
Doesnít sound like the pedal feel on my WK1. Are you sure you didnít get air in the system?
19 Sting-Gray WK2 Trailhawk | Hemi | MRR | Ridge Grapplers
08 Silver WK1 SRT8
gspfunk is offline
post #4 of 7 Old 10-23-2019, 02:57 AM Thread Starter
JDePietro
JDePietro's Avatar
2005 WK
I’m as sure as I can be. I run a hose into a clear bottle full of fluid and watch until the bubbles stop. Fluids in air out is how I’ve always done it. The rear calipers are still the originals but they were in fine condition. I should mention she has about 138k on the clock.
post #5 of 7 Old 10-23-2019, 06:49 AM
acabtp
2005 WK
if air got in the ABS module then you need to purge that with a scan tool (or by activating the ABS a few times on snow/gravel)
'05 WK Limited 5.7 Hemi
acabtp is offline
post #6 of 7 Old 10-23-2019, 11:58 AM
Avs
2006 WK
Originally Posted by JDePietro View Post
Iím as sure as I can be. I run a hose into a clear bottle full of fluid and watch until the bubbles stop. Fluids in air out is how Iíve always done it. The rear calipers are still the originals but they were in fine condition. I should mention she has about 138k on the clock.
Are you using a two person brake bleeding process or you hook a power bleeder to the master cylinder?
Avs is offline
post #7 of 7 Old 10-23-2019, 03:13 PM Thread Starter
JDePietro
JDePietro's Avatar
2005 WK
I did the whole gravel road lock em up scene. I used the two person method.
At work I drive a mixture of 2013> Ford Exporers and Dodge Durangos with the emergency package, my wife has a 2010 Jeep Liberty and my other car is a Scat Pack (Not comparing) and of them all the WK is right on the bottom for breaking performance. I'm wondering if changing out the rear calipers would have any impact.
